Alignment?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by outlaw612, May 14, 2002.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    How do you do an alignment on a solid axle truck? I think I had heard something about shims, but dont remember where or how.
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    i know to set toe you just adjust the tie rod to make the measurement on the front and back of the tires...if you know what i mean
    Later
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Caster you shim the axle at the springs. Camber you shim the spindle at the knuckle.They make round shims that are thicker on one side.
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Unless you think you have some kind of problem, just set the toe and go.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Do a search. I posted exactly how to do this a little while ago.
  6. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    There are also offset upper balljoint sleeves up to 1.5 degrees which is more than you should ever need.
