alison/big auto trans questions
Discussion in 'The Garage' started by big_truxx, Feb 17, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    I have never seen a big truck auto like the alison and I was wondering if they have the "bellhousing adapter" thing built into them just like on a TH400 lets use for an example. Thanks :waytogo:
  2. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    i have a allison at540 from c-60 school bus and it has a bell adaptor that is cast iron. you bolt it to block and then bolt flywheel to crank . its a special hd unit. this all bolts up to tranny and convertor. the adaptor is full 360 bolt pattern on tranny. if you want 1 let me know i will sell this cheep. its a reman unit , from allison.
    you can get different adaptors for different motor combos.
  3. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    I was just curious as I have never dealt with the big autos before. I am researching info for a project idea I have. I was thinking about running something like an alison auto behind a 3116 CAT in my DD after I get the first CAT swap done with a manual in my 84. :waytogo: thanks for the help
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Most of the current medium & all of the heavy Allisons have an integral bellhousing in one of the SAE-standard round patterns. A couple of the smaller Alli's have different patterns, depending on what engine/chassis mfr. they designed and built the unit for.
    The couple of heavy ZF autos I saw in the shop had a similar, but different round bellhousing bolt pattern. Maybe it was an European standard, I dunno...
    ***EDIT*** Just looked at sweetk30's pics a little closer, and I recognize that tranny. My former employer (as of yesterday - woohoo!) moves dozens of these a day - apparently they're popular, so parts won't be difficult to obtain.
  5. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    sweet! now to further research and find out what sae pattern each auto is and what a 3116 and 3208 cat requires :thinking:
    thanks :waytogo:
  6. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    can anyone tell me which trans would have the SAE#2 bolt pattern?
  7. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    also another question. the alison autos that I would be using for the CAT 3116 do not require and sort of computer eletrical hookup do they?
  8. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Depends on the vintage. An older one will probably only require a shifter linkage and some sort of speedo cable. Some of the newer ones use a "touchpad" shifter; some are meant to be behind a computer-controlled motor and need inputs from that computer. Some have electronic speedo pickups and need a compatible speedo to go with it.
