All 4 wheels spin except when....#PICS#
Discussion in 'The Garage' started by stallion85, May 12, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Front Dana 44 with limited slip
    Rear 14ff with Gov lock
    here is what I did, I put the truck up on jacks and tried to spin one tire front then went to the rear. Both ends only one tire turned of course the one I was spinning and the other just stood still. I then started the truck put into 4hi and low gear. I let off the clutch and all 4 wheels were spinning in the forward direction. I then tried to stop one tire on the front and rear and had no resistance in the front and little in the rear. Is this crap working right? If not what could I do to fix it without the same old CK5 qoute,"Get a detroit baby"
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    thats definately not a limited slip front diff. it's open as open gets. I can't tell about the rear, but it sounds like it too.
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Yeah the D44 is open for sure... I am not 100% on this, but i think a Gov-Loc works by allowing one tire to overrun the other to a certain speed and then once one wheels is overrunning the over by that speed, it will lock up...But I am not for sure on that...I am a DEEEEETROIT boy myself (F&R)
    Chris
  4. Grim-Reaper
    7,385
    Atlanta
    That front limited slip is not going to lock till it gets some power behind it unless the clutches are smoked. I can about gurantee that if you got both rear wheels off the gorun and one front wheel of the ground and gosed it it would pull.
    Same with Gove locks. They have a weighted axtuator that also needs the wheels to trun at different speeds to work. Again the clutches could be smoked.
  5. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Front could be like a Trac-Lok, which uses clutch packs under the side spider gears, so it looks like an open diff but its not. The front is probably wore out in this case, with my trac-lok dana 44 both tires spin the same when its jack off the ground.
    With the gov-lok 14 bolt, which that is, it does not work like a typical limited slip with clutch packs. It has some gizmo's and widgets and what not inside, so it acts like an open diff a lot of the time, such as having the tires off the ground as described. With a 14bff gov-lok, probably most gov-loks, I think they work like an on/off switch as far as function goes. Difference is its more like works/broken with the gov-lok /forums/images/graemlins/rotfl.gif
  6. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    gov lock works by tire rotation. It basically stays open until one tire spins 100 rpm faster than the other. Then a governor (hence the gov in gov lock) locks the rear diff. The 14B gov locks are pretty strong. The 10 bolts are gov bombs. The problem with a gov lock is that by nature you are running an open dif until you lose traction. Once the tire starts to spin you have a lot of rotational mass whit a good bit of energy that goes up the bigger the tires you have. Once the gov lock engages you put quite a shockon the side that isn't spinning. So when someone runs 35s on a 10b gov lock and gets in the skinny pedal things are bound to break.
  7. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    just a thought try putting it in 2hi, and have half yer truck on gravel, other half on pavement, then floor it, if ya go then it is a limited slip, or gov-loc or whatever...if it doesnt it's either smoked or non-existent...and for the front this may not be safe but its all I could think of quickly...lift the rear up and support with jackstands. have the front tires one on gravel one on pavement put in 4hi and then floor it, if you just spit gravel you've got a toasted limited slip, or just and open diff, if it pulls ya off the jackstands then yer good to go..and hopefully didnt damage anything trying. just a thought
  8. bgchvy79
    bgchvy79 1/2 ton status
    Jan 3, 2004
    108
    Moore, SC
    do not post this kinda crap again /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  9. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Zach your new so I'll say it nice. Language like that is NOT tolerated here at all. This is a family site. If ya wanna talk like that move on to pirate 4x4.
  10. bgchvy79
    Jan 3, 2004
    108
    Moore, SC
    you might do that with your family but we do not tolerate it here this is the last time you will be warned /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  11. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The front looks like a Trac-lock....note the plates behind the side gears and the retaining clip. If you can either spin one tire by hand and the other tire does not move, or you can hold one tire still while the other spins (with the truck on jackstands) then it is either completely worn-out or something is broken.
  12. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    You can check the operation of the rear gov-lock by jacking up the rear of the truck and spinning one wheel. Fast! Give it a few hard spins, then WHAM! /forums/images/graemlins/shocked.gif The lock will engage and stop the spinning. While off-roading it's hard to tell if it's working as there is no wham /forums/images/graemlins/rolleyes.gif. Personally I really like the gov-lock , and won't be buying a detroit unless it quits working. good luck.
  13. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Sorry, I got back to this post a little late. You guys identified the front as a track lock, since the spider gears are still there could I put a lock rite up front or is the carrier useless now. I could rebuild the ls, but would rather have a locked front end. Also the gov lock in the rear....what would it take to put a detroit in it. I know I need a different carrier but how can I get one /forums/images/graemlins/thinking.gif I am not quite sure what the carrier is. I know what the ring gear and spider gears are, still learning about this stuff /forums/images/graemlins/whistling.gif Any ideas or experience would be greatly appreciated /forums/images/graemlins/thumb.gif
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That carrier is junk. You might as well buy a detroit if you decide to lock that axle.
  15. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    If I buy a detroit does it have it's own carrier or what? WTF is the carrier exactly??? /forums/images/graemlins/rotfl.gif
  16. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    that front is definately a trac-lock (Sp?) the same thing that comes in zillion of jeep dana 30's
    mike
  17. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Can a rookie garage mechanic rebuild a trac loc and if so who sells the rebuild kits?
  18. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Yes just about anyone with a slight mechanical aptitude can rebuild a T/L .
    The tricky part is getting the belveld(sp) spring to compress enough to get the small spider gears in along with the thrust washers that go behind them .
    A good trick is to get a large bolt & nut , along with two big heavy duty washers and compress each side so that the belveld spring compresses when you install the internals .
    Any differential/gear wharehouse should carry the clutches for a Dana 44 T/L NOTE: 3.92 and up carriers use an extra clutch disc so the clutch retaining clips are wider than the 3.73 on down carriers.
    As stated a few posts above YES that carrier IS a T/L not an open diff .
    HTH , Tom
  19. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I found a rebuild for the Trac lock, Will this work and is this an ok price. I figure for $50 I can have a little more traction till I get a locker /forums/images/graemlins/waytogo.gif Look here for product
  20. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    Actually, the nic name "gov-lock" which was given to the Eaton locker refers to the governor which doesn't allow it to lock up over 20mph.
