All aftermarket gauges?
Discussion in 'The Garage' started by Veefour, Nov 25, 2005.
  1. Veefour
    Veefour Registered Member
    Jun 7, 2005
    54
    North Carolina
    Has anyone replaced ALL of their dashboard gauges with aftermarket ones?
  2. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    yes. we have at times. do a search to find pics. good luck . i can send you pics if you want? email address?
  3. Veefour
    Jun 7, 2005
    54
    North Carolina
    I did a search on aftermarket gauges, but ddin't find anything on an ALL aftermarket dash.
    email is in my profile info. Would love some pics and information on which gauges were used.
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    here ya go...
  5. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Yes, I replaced ALL of mine with digital (Intellitronix) gauges. I even added some that were not there originally. I have speedo, tach, gas, coolant temp, oil temp, trans temp (screwed into the fill plug on my SM465), voltage, oil pressure, fuel pressure, and air/fuel ratio. It's all mounted in a cut down ammo can that fits in the dash (with only minimal mod cutting the corners of the gauge cluster hole square instead of rounded). I'll try to get some pics tomorrow. It's pretty cool, and when I go mudding I can snap the lid on the ammo can and have instant water/mud proof protection. I'm working on a window in the lid for permanent protection.
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    :thinking: :thinking: Don't forget those pics....
  7. guido666
    Feb 16, 2005
    788
    Longmont, CO
    I won't but it's been dark out here for a couple hours.
  8. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I gotta see this!:bow:
  9. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    ryoken, that is badassss....... :bow:
  10. aduff85k5
    aduff85k5 Registered Member
    Dec 31, 2004
    91
    florida panhandle
    yea your dash is damn fine there. what are you guaging? seed, temp, oil pressure, trans temp, outside temp, temp in hawaii?
    very nice
  11. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    thanks guys... kinda dirty in that pic, but you get the idea... there are a bunch of threads on it, so some searchs should bring up stuff..
    its fuel, volt, water temp, oil pres, oil temp and tranny temp..
  12. Veefour
    Jun 7, 2005
    54
    North Carolina
    Ryoken, what brand Gauges are those?
  13. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Now mind you this is for ruggedness and functionality. It is made out of an ammo can I found at the surplus store for $5. I can take pictures of the unused one and post dimensions if someone cares. It was originally about 10" deep, I cut it down so that it is now about 3-1/2" deep and the gauges are set in 1" (the electronic gauges are only 2" deep!). You can see in some of the pictures where I had to square the corners of the dash cluster opening in the truck, but that took 5 minutes with a dremel. I welded little pieces of angle iron to the sides and drilled holes in them, this box mounts in the ORIGINAL gauge cluster's mounting holes (the little sheet metal clip things) so if I ever wanted I could put back the original gauges, and take this with me. You can see some mud on the faces. :D But I can snap the ammo can's lid on (with some modification to the latch down mechanism, replaced with square u-bolts and wingnuts) and seal the whole thing up for hardcore offroading. I want to cut a hole in the lid and put a window in it, but haven't had time yet.
  14. Veefour
    Jun 7, 2005
    54
    North Carolina
    Thats really cool. Amazing what you can do with spare time and power tools eh?
    Im not a fan of digital gauges, but that really does look great.
  15. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Mad Max
    There's some people in Hollywood that can can help you with that problem.:D
  16. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Autometer pro comps.... silver trim rings repainted to match dash/truck color...
    Guido, not a digital fan most of the time, but i'm digging the ammo box... :D
  17. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    This was a magic moment, 180KM. Off screen on left is Volts and B&M trans temp.
  18. sweetk30
    Nov 1, 2004
    25,552
    547
    auto meter phantoms.
  19. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  20. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Where did that "Lev-O-Gage" come from?
