ALL Cadillac Eldo Caliper people HELP!!
Discussion in 'The Garage' started by CaveBlazin, Nov 23, 2003.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Ok I was trying to adjust my ebrake lever and the DAMN piston just popped out. Is there some kind of trick to get this thing back in its home. JUST GO TO YOUR HOME!!
    I tried getting it back in there and turning the bolt on the ebrake but it just turns and turns like its not catching on that huge bolt on the inside?? HELP!!
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Your not going to want to har this....But apparently if the piston comes out, they DONT go back in...I remember the guys at offroad.com accidentially did this and had to buy new calipers.
    Hopfully somone will come out an contradict me...:S
  3. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    PLEASE SAY THIS AINT SO!!! SOMEBODY OUT THERE AHHHHHH
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've had both of mine completely apart to rebuild 'em. /forums/images/graemlins/cool.gif Don't worry about the jack screw too much. Take the lever off of the jack screw and remove the screw from the bore. Now turn the piston so that it is open-side-up and insert the screw into the piston. Next, hold the caliper so that the piston bore is facing down and insert the piston from the bottom. You can use a big C-clamp to get it started. But don't go too far with the clamp, as part of it will be covering the hole where the jackscrew comes out. /forums/images/graemlins/shocked.gif
    Once the piston has started into the bore, remove the C-clamp and insert a 3/4-inch (or so) socket between the caliper and the clamp, so that the open part of the socket faces the hole where the jackscrew will be coming through. Now continue pressing the piston into the bore until it is fully seated. The end of the jackscrew will come through the hole in the caliper and then you can reinstall the e-brake lever arm. /forums/images/graemlins/thumb.gif
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Oh yeah, don't mess with the e-brake lever any more until the caliper is ON the truck and has pads installed. /forums/images/graemlins/wink.gif
  6. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    *was sweating like two rats screwin in a wool sock there for a minute* I'll try that now thanks Harry!!! /forums/images/graemlins/thumb.gif
