All electric dash?
Discussion in 'The Garage' started by PsychoticDeadGuy, Oct 18, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    I have a 87' K5 with the stock dash guages and a aftermarket tach. could i order some of those fancy lightup LED guages? the back of my guages all have those screw thingys that the wire goes onto. any one do this or know of a set of guages that will look good and work easily?
    edit: I am looking for some digital gauges. thanks
  2. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
  3. PsychoticDeadGuy
    Jan 8, 2005
    753
    what about part number NRD-DP9255 over on summit.com? i know it doesnt say its for a truck but it does say its for a el camino...i dont want to spend over $500...anything else? i will be making a new dash when i get my cage in.
  4. dyeager535
    26,975
    Car gauges are quite a bit different than trucks. Actually a lot. The general idea is the same, but size and connections are different. Anything can be made to work, but that would take a lot of work to make look good.
    The gauges are lit by the twist in bulbs, what are you talking about with wires going to the back of the gauges? Stock they don't have any exposed wires, it's all PCB. You can buy replacement 194 bulbs that are LED's, (ebay probably has some, a google search will net thousands of results) but I have no idea how they handle the dim feature, and if it's your job to cut down the voltage going to the new bulbs.
