all i need is a few answers
Discussion in 'The Garage' started by stiches, Nov 20, 2005.
  1. stiches
    stiches Registered Member
    Nov 16, 2005
    72
    vallejo/lodi, CA
    Hey, i am here with a 78 blazer...4 or 5 inch lift don't know what tires...i am wondering is it bigger tires faster you go or slower you go? i don't have a computer to reset the mph someone help
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    If you put on larger tires and change nothing else - the truck will be going faster that the speedometer shows.
    :D
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    bigger tire = faster than the speedo shows.
  4. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    reply
    Okay i thought so.....anyway to fix that?
    also
    does the radiator need a fan shoud?
  5. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Yeah, it helps. Fan shroud helps to pull air through the radiator to cool the engine.
    A buddy of mine put a body lift on his 2000 z71 and the fan shroud had to be modified. Before he fixed it, the truck ran fine on the highway but the temp. would climb when muddin. He would have to shut it down and watch until it cooled off.
  6. seattle73k5
    seattle73k5 1/2 ton status
    May 6, 2005
    210
    San diego/Camp Pendleton
    you can get new speedo drive gears for the tranny they are simple to change and pretty cheap. some site's have a speedo gear calculator so you can get the right gears. may not be spot on accurate but it gets you dang close within a MPH or 2.
    Do a search on here there is a few that will pop up about it.
  7. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    sounds good...
    also an urgent matter
    My battery keeps dieing..i['m not totaly sure its the alternataror but i can drive for like 15 mins then its dead no juice...how hard is it to change the alt?
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    loosen the bolts that hold it in and move it, which will loosen the belt and then loosen the wires in the back and should come right out.
  9. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    i'm just going to go down and spend the 40 for a reman...or should i go for a junkyard
