All Mechanics, please help
Discussion in 'The Garage' started by 19Jimmy87, Aug 30, 2002.
  1. 19Jimmy87
    19Jimmy87 Registered Member
    May 9, 2002
    65
    Kalamazoo, Michigan
    This is a garage and you all are a good source of knowledge. In my 95 Acclaim, I was driving on the expressway and the I could not accelerate. No noise, smoke, and I still had A/C and the radio. It has 86000 miles and I thought the engine was good. Any ideas? I would like help before the shop gouges me for more. Thanks.
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    More detail...? When you gassed it did it eventually go, or just nothing period and that is that? Does it run now? If so does it do anything funny while running at an idle?
  3. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Bad fuel?
    Dirty aircleaner?
    Clogged fuel filter?
    Floor mat under the accelerator pedal? (dont laugh, Ive done it, troubleshot for 2 days on that one!)
    Like steph said, MORE INFO PLEASE DANG BLOOBIE!!! j/k
  4. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    catalytic converter??
  5. katie
    katie Registered Member
    Aug 9, 2002
    8
    ROCHESTER NY
    No accelration...
    My Mercury Sable beater did that it was the catalytic converter
    check it out. Dont run it too long if it is that.. I found out the hard way.. /forums/images/icons/crazy.gif /forums/images/icons/crazy.gif /forums/images/icons/frown.gif
  6. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Also could be a bad fuel injector or an upstream blockage in your C02.... I had symptoms like these and these were the problems I had... /forums/images/icons/tongue.gif
  7. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    If it died and didn't restart, you most likly broke your timing belt. When cranking it would sound diffrently than anytime before. Like there was no restriction, just spinning free. If it did restart let us know. /forums/images/icons/grin.gif
  8. 19Jimmy87
    May 9, 2002
    65
    Kalamazoo, Michigan
    And the winner is...the timing belt.
    Thanks for replying
  9. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Are you going to attempt this fix or have it done?
    If you want to do it (it is time consuming but relitivly easy,depending on your experance/tools) I can help you. If you have the 2.5l 4cyl. You most likely will NOT have valve issues. If however you have the 3.0l 6cyl. you very well may have some other damage. But it could go either way. /forums/images/icons/grin.gif
