All You 14 Bolt Rear Enders
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Aug 23, 2001.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    When you installed your 14 bolters, did you have to modify anything? Spring perches? Drive shafts? U joints? U bolts? Found one in a junk yard for 150.00. Guy told me it needed mods to fit into my blazer. I really have no idea. Toss this dumb ol' dawg a bone!
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    if you have a 14B FF from a 3/4 ton then they are a direct bolt up (except for the ubolt's have to be wider to accomidate the axle), but if you are talking van or 1 ton then spring perchers and shock mounts have to be fitted.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    So I need to bring a smart stick and do some measuring then......... that means thinking and I don't like THAT!
    Jim
  4. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    LOL... yea, I'm sure everybody here can sympathize with that!
  5. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    You may need to fiddle with the e-brake cables to get them to work. And you need a hybrid u-joint for the driveshaft. Like Solo said, the perches are different on 1 tons and vans. MEASURE THEM YOURSELF!!!!!!!! Don't take his word for it. He wants to get rid of the axle and will tell you anything to do it. Also check that the gear raio is the same as yours unless your redoing your front too. Let's see.......what else........oh yeah, if your gonna install a detroit in it now or later make sure it's an open diff. BTW I got mine in a Bone Yard for $95 including exchange.
    <font color=blue>Esteban</font color=blue>
    <font color=red></font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/Estebans-album>Take A Gander At My Truck Here.</a>
  6. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Read Steve's axle swap article, it should clear some things up:
    http://coloradok5.com/gallery/K5Jungle
  7. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    150.00... it's worth buying then reselling to make a profit...
    But I got my 14 bolt in finally..
    Wes "thatk30guy" was kind enough to relocate the spring perches and move the shock mount's higher up the tubes..
    14 Bolt's are well worth their weight in gold..
    It's a win-win situation regardless... won't take much to make it fit..
    U-joint you'll need is Napa Part # 447
    I got a Neapco U-joint they cross referenced with the Napa part #...
    Good luck.
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  8. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Depending on your lift you will need to cut and weld the perches to get a better driveshaft angle. The angle wasn't so bad with my 10 bolt but then I threw in the 14 and the Vibes started to hit.
    Surfing is Life...
