All you 465/205 folks please read
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Oct 3, 2001.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    On my truck right now I've got stock exhaust manifolds that I'd like to replace with headers. My question is, which headers work best to clear all the clutch stuff and make it easy to route the passenger side pipe around the Tcase? Thanks in advance.
    '73 K5
    Chevy good...Ford bad
  2. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    Got Dynomax ceramic coated ones! No clearance problems with the clutch stuff but no 1 and no 5 spark plugs are close!
    Ron
    '84 K5......Tree Fitty, SM465/Np205, D44/14BFF, Pro-jection! .....and of coarse no other color than Odie!
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I've used Mr. Gasket [​IMG] and Flo-Tech. Both fit with some minor tweaking. The clutch linkage was no problem, but the collector is close to the front shackle.
    Rene
  4. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    I have never had any problem with my flowtech headers.
    eric
    Don't get me started, you know how i get.
    82k5, 14bff, d44, sm465, np205, 300hp350, rust
  5. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    I have heddman torque step headers and all i had to do was remove the starter to get the headers to fit in and it wasnt to bad puttn the starter back in.
    350, sm465, NP205, 14ff w/detroit, yucky ten bolt 4" springs,38.5x14.5 swampers
    <a target="_blank" href=http://www.planettribes.com/theden/gontw/nsig.jpg>http://www.planettribes.com/theden/gontw/nsig.jpg</a>
  6. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I have Flowtech Afterburners. They say those are not supposed to wrok with manual trans, but there is plenty of clearance. I have had them on a 74 and an 83, both with the 465.
    Guess somebody didn't do his homework [​IMG]
    Still Poundin' "pavment" after all these years!!! [​IMG]
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    From my experience, I would not use the Flowtech's on the small blocks. They hit the shackle bolts on one side, can't remember which.
    I got Hedman headers to replace those Flowtech's and they worked better. Lot more clearance around the shackle bolts and these headers I got were the longer tube types. Do not get the shorter Hedmans.
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  8. Medman74K5
    Medman74K5 Registered Member
    Jun 7, 2001
    48
    Arizona, Prescott Valley
    I've got Flowtech's and they were rubbing the front shackle bolt on pas. side. Just shortened the bolt prob. solved.
  9. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I have dynomax on mine and they clear all the linkages and shackles . but like they said above a couple of the spark plugs are a pain.
    A BIG HAMMER CAN FIX ANYTHING.... [​IMG]
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've got Dynomax, only problem was passenger shackle bolt, sawzall and cutoff wheel solved that!! Mine is an automatic right now though (4 speed in garage, going in December '01).
    #6 plug is a biotch, others are simple.
    Tim
