all you on 3/4 runinig gear, gime a hand
Discussion in 'The Garage' started by dodgetruck91, Nov 5, 2003.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    i am going to 3/4 ton runing gear soon. what i iwana know is what do i al need to chahnge IE, driveshaft lengths, u joints, break parts, shohck parts, and what tis this floater thing i hear a bout? any help would be apriciated!
  2. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    depends on what you get the 3/4 ton stuff from and if you have a d44 or ten bolt up front with a 10b it will a;; be a bolt in swap if you use a 14bff rear you will need a new u joint for the rear rvery thing else should be a direct fit. If its a d44 front then you will have to change the break lines. On my 72 I moved the shocl mounts so they are both on the front of the axle like the origanal 12b instead of the front back that waas on the axle but I think in a second gen the shocks may be front back mounted.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A little punctuation and sentence structure goes a long way.
    1. Now would be a good time to re-do the brakes on the axles you're swapping in. Seals and gaskets might not be a bad idea either.
    2. You will need the combination u joint for the rear either 3-3140 or 2-1153 depending on if your truck uses a 1310 or S44 joint right now.
    3. Shocks will probably bolt on fine
    4. Check your e brake cables. Another member can help you better with this stuff as I don't run an e brake.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I just did this swap this past summer, so it's all pretty fresh in my head. I wish I was back home, I'd gladly run over and give you a hand, but I'm in Madison for school and have a very minimal amount of freetime.
    Here's the basics:
    - Use the calipers from your 10 bolt on the new 3/4 ton front...that way you won't have to bleed the brakes up front.
    - I found that I have to buy a driveshaft spacer for the D44 I put in place of my 10 bolt up front. The splines are just showing (if you can picture what I mean) at full droop, and they weren't like that with the 10 bolt.
    - Take Tim's advice and look over/replace the brake parts on the rear axle. Especially do the wheel cylinders on the rear axle. $15 per side and it doesn't require removing any springs, shoes, etc provided those are all in good condition anyways.
    - You'll need a combo u-joint as stated above for the rear...the front will bolt up fine.
    - Wisconsin requires a working mechanical e-brake. It sorta takes a little custom work to get the e-brake cables to work because of the different way they mount in the backing plate. I'll post some links to the posts that helped me when I had to do this.
    - A "Full Floater" axle is the "heavy duty" 14 bolt if you will. In a full floating axle, the hubs bear the weight of the vehicle just like the front axle and the hubs are held onto a spindle with the same type of nut/lock washer configuration as the front. The axleshafts bear no weight of the vehicle (they do in a semifloating) but rather only supply the driving force.
    - Remember that if you're going to a 14 bolt FF from 1/2 ton stuff, you'll need 8 lug wheels.
    That's all the big things you have to watch out for. If you have any specific problems along the way, feel free to shoot me an e-mail. I know you can't send PM's because you aren't a member, but my e-mail address is in my profile.
    Oh yeah...there are pics of the swap I did in the link in my signature.
  5. heavy4x4
    Aug 28, 2002
    3,270
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    If your changing from a 12 bolt to a 14bff You might need to shorten your rear driveline.. I did 1 inch.. /forums/images/graemlins/eek.gif
