Allan's cleaning house again
Discussion in 'Pacific Region' started by mountainexplorer, Jul 10, 2005.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    So, I got myself into another situation where I'm supposed to be in Oregon within 2 weeks with $5000... and I have about $750 so far. So, I'm selling off a bunch of stuff again. If you happen to hear of anyone looking, the following is for sale:
    1980 Chevy 3/4 ton 4x4, stock 454 with headers, 465 4spd, NP205, 14-bolt rear, Dana 44 front with new balljoints and wheel bearings, 35" BFG's, 6" lift, new shocks and front bushings, new clutch, rust free bed. Cab needs cab corners. $1700
    1978 K5 Blazer 4x4, 350, TH350 K-case, Part-time 203, 4" lift, 33" Thornbirds, dual exhaust, tilt column, posi rear end, needs windshield. $1500
    1977 Chevy 3/4 ton 4x4 Crew Cab, 350, rebuilt TH400, part-time 203, 4" lift, 14-bolt posi rear, Dana 44 front, tilt column, factory tach, newer dual exhaust, new radiator, Knapheide locking utility bed. Cab has rust. Front fenders rust free and bed in good shape. $2000 or $1800 w/out utility box.
    1974 International 3/4 ton 2wd, 304 V8, 4spd, Utility bed, nds starter and battery. $450.
    Complete strong running 454 motor, 1973 3999289 casting block, 1973 781 casting oval port open chamber heads, complete longblock with all brackets. SOLD
    .040 over 454 block (14015445 casting), rods and crank, bearings went bad. Disassembled shortblock, $300.
    1967 396 shortblock BBC motor, originally out of a '67 Camaro, .030 over, steel crank. Shortblock, needs rebuild. $500.
    10-spline NP205 T-case $100
    14-bolt Full-Floater rear with 3.73 gears SOLD
    TH400 2wd tranny out of motorhome, with torque convertor, $125.
    Dana 44 8-lug 3/4 ton front end out of a 1972 Chevy, 4.09 gears, flattop knuckles, large Spicer hubs, $175.
    1973-1980 Chevy truck straight hoods $20 each.
    1973-1980 tilt automatic steering column $80.
    Hydroboost brake booster and lines $50
    4x4 steering box $25
    Pair Suburban rear barn doors, 1981-1991, $150/pair
    Single rollbar out of 1973 K5 Blazer $50
    GM Dana 44 1/2 ton front end, Warn hubs, 3.07 gears, $100
    GM Dana 44 1/2 ton front end, 3.73 gears, $150
    GM 12-bolt truck 5-lug 1/2 ton 2wd rear end 3.73, $150
    GM Dana 70 HD Dually 1-ton rear end, 4.10 gears, complete, $325
    1984 Chevy Crew Cab 4x4 1-ton frame and cab only. No running gear. Frame, rear springs, cab (has rusty floor) and bed, with title, $150 and you haul.
    Dodge Dana 70 3/4 ton rear end, 3.54 gears, $200
    1990 12-valve Cummins 5.9L Turbo Diesel motor and 3spd automatic 4x4 tranny, 225k, mostly complete. (sold)
    PTO 8000lb Ramsey winch and bumper (minus cable), was mounted on a Scout, $250.
    And here's stuff I won't sell unless I absolutely have to, which is why I overpriced things:
    GM NV4500 5spd 4x4 transmission, no bellhousing. I never drove it, but got it as a used unit. $1200.
    Older upright style Warn 8000lb Electric Winch $350.
    Edelbrock Performer BBC aluminum intake $130.
    Complete running 454 with 12k miles since rebuild, 14015445 block, Edelbrock intake, can here run, came out of 25ft motorhome, currently in my '81 Crew Cab and can hear run/drive. Complete motor $1000.
    Edelbrock 750 cfm electric choke carb, nds rebuild, $100.
    1988 Pontiac Firebird, 2.8 V6, 5spd, runs and drives. Needs steering column bearings and mount for transmission. $500.
  2. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    roll bar? whats it look like?
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    He has roll bars out of a 1st gen 69-72 and a early 2nd gen 73-77. Neither would work for your mid 80's K5 unfortunatly.
  4. coptezr
    Jan 13, 2005
    342
    damn
  5. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    first in line for the 8lug d44... :D
  6. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    dang man yer cleaning house!
    Those 35's on the '80 3/4 ton, what size are they? are the 16's or 16.5's? Are they the mud terrain, or all terrain? if they are 16.5's and mud terrain, would you be willing to sell just those?
  7. mountainexplorer
    Nov 14, 2001
    4,903
    They are 35x12.50R16.5 BFG Mud Terrains. They aren't the greatest. I don't really want to sell them, since I had to take the tires off my Suburban to put on this truck to sell it, since I didn't get tires with it. I don't really have another set to throw on it except some unbalanced 38's.
  8. coptezr
    Jan 13, 2005
    342
    allan you get my pm?
  9. mountainexplorer
    Nov 14, 2001
    4,903
    Got it. You'll have to talk to Travis about the 14-bolt.
