Allen wrench question - help!
Discussion in 'The Garage' started by TX Mudder, Jul 10, 2004.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Ok, I have an allen bolt that takes a 3/32" allen wrench. I have stripped 2 allen wrenches trying to remove it.
    Two quetions:
    1. Do they make higher strength allen wrenches? Maybe mine are just cheap. Where can I find them?
    2. It is possible someone used red loc-tite on this tiny allen bolt. Isn't it true that if I heat it up to like 500 F the loctite will let go? I have an oxy/acetylene rig that I use to cut steel. Is that OK to use? The steel that this bolt is in is heat treated and I do NOT want to anneal the metal, or whatever it is called when you soften it.
    Someone help me as I feel dumb not being able to get this little booger out.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive learnt that the more money you pay for the allen wrenches, the stronger, better fitting they are.
    did you try a torkes bit? just take one about the same size and tap it all the way in and use a ratchet to break it loose
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Yes, if it is lock tite in there, the only way to get it out is to heat it up. Like big83 said, the more expensive allen keys are better. I stripped 3 allen keys trying to get some bolts off the front hubs. because they were cheap ones.
  4. dyeager535
    26,979
    I have heard (maybe mis-heard?) that if you don't quench the metal, (IE change the temperature very fast, like dipping in water) you will NOT affect the metals "heat treatment".
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I took your advice. My smallest tork-head(sic?) bit fits snugly in the 3/32" allen head. With a ratchet and some even pressure it came off great. There were actually two bolts and they both came out with this. I didn't see any loctite so maybe it was just very snug and made of high qaulity steel, and my allen wrenches were not up to task. /forums/images/graemlins/dunno.gif
    Thanks for the advice! That's why I love this place!
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    NO No quenching metal from diferent heats, into diferents liquids is a way TO temper steel!!!
    when you heat up some thing and it cools it is usuals weaker!
    if something is tempered/heattreated use heat sparingly, if so your ok but if you heat something up alot (glowing, ever cherri red) you will lose you temper.
    if i wanted to heat a bolt that was on tempered steel i would heat it up a little, then let it cool. Just a bit,then again, then try to crack the bolt. little by little.
    i have gotten very stuck ball joint nuts off with a plumbing torch /forums/images/graemlins/weld.gif 2 min. and comes off smoo /forums/images/graemlins/waytogo.gifth!!
