Allison 5-Speed Automatic
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Gandolf, Oct 15, 2000.
  1. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    Chevrolet is offering an Allison 5-Speed Automatic as an option in some of the 2001 Pick-ups. The Allison has been around a few years in some high end motorhomes. It sounds like the ultimate heavy duty transmission cuz in the pick-up, it has a 7 1/2 Ton towing capacity. I have two questions.
    1. Does anyone know more about these transmissions, such as: will they bolt up to our 350's and transfer cases, availability, cost, etc. and 2. Who is going to be the first kid on the block to have one of these in their Blazer?
    '89 K5 Silverado 4" lift w/BFG 33's
  2. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    they also used allison trannys in garbage trucks. i can hardly wait for chevys new line up so i can drool all over. i also hear they are going to build a new bad a$$ disel engine
    <font color=green>SMP</font color=green>[​IMG]
  3. waterboy
    waterboy Registered Member
    Jun 8, 2000
    48
    actually the diesel is made by isuzu its 6.6 turbocharged strait injected with 300 hp stock and it blows those 7.3 liter fords out of the water their bad boys
  4. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
  5. I just read the flyer Saturday and I believe it said the Allison was a 6 speed !!
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    As usual, something to keep in mind (for K5's) will be the overall length of this tranny. Plus, you may have to settle for whatever t-case GM chooses to put behind it.
    It would be nice, though, if it will work...
    [​IMG] Semper Maintenance!
  7. 82GMC
    82GMC 1/2 ton status
    May 14, 2000
    553
    Seattle Washington
    BigBurb the allison is a 5 speed it's the manual thats the 6 speed.
    This is the same 6 speed that ford and dodge started putting in their trucks last year,But I think some of the gear ratios are differant.
  8. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    The trans is a6 speed the same as in the new top kick and the motor is chevrolet and Isuzu as in General motors owns controling stock in Isuzu
  9. I was wrong
    Yep I read it wrong or had it backwards !! The Manual is a 6 speed and the Automatic is a 5 speed, they both have PTO capabilities which mean that down the road you can buy one to add on for a PTO winch or other accessories !! They both look like they would be a monster of a tranny. They didn't say what kind of transfer case they are bolting up to this thing. Maybe a hybrid NP 205, I know a Atlas II !!
  10. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Re: I was wrong
    allison trannys are a serious trans. very heavy duty. as far as I know, the allison tranny was not available as a 4x4. but there are companies that make the conversion. but they usually make them to fit the heavy duty rockwell t-cases. I have never seen a 205 adapted to one.
    your right. I don't understand the jeep thing!
