Alloy Shafts for D44
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RedDwarf, Aug 8, 2001.
  1. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    So who here has broken an alloy shaft? What gears/tires?
    Lift It, Lock It, LIVE IT!!!
  2. RedDwarf
    May 9, 2001
    816
    Re:Breaking Alloy Shafts for D44
    Or, who has them and has dogged the crap out of them w/o breaking?
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I popped a ujoint one time that twisted the ears up a little. Maybe repairable, probably not. We've had to run a few warranty shafts through here, but most of them are joint caused problems, and the 2 or 3 shafts we've seen broken have been with 38" and up rigs. If you twist the splines, you get a new shaft pretty quick.
    I used the truck really hard a couple of times with 35.5" TSL's and a lockright trying to get up the Dumpbump in Moab. All kinds of bouncing and thrashing about, was really surprised they didn't turn loose somehow. With 37's, it was a lot easier to break them, one good hop would do it. But at that point, I was running the hub fuses so it wasn't too bad to break them.
    Making the world better, one truck at a time.
    SW-ORD<P ID="edit"><FONT class="small">Edited by Stephen on 08/08/01 06:55 PM.</FONT></P>
  4. RedDwarf
    May 9, 2001
    816
    Hey thanks Stephen, that's the kind of info I was looking for.
    Unfortunately, I have 38" TSL's, but they only measure about 35" tall on the truck.
    So if the splines twist, you guys will warranty them?
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Basically most of the shafts I believe have a lifetime warranty... someone correct me if I'm wrong. Basically w/ 38's and up w/ a locked frt end you are gonna break stuff in a D44. The nice thing is sometimes you can luck out when a u-jt blows in an aftermarket shaft and not kill the ears... but that is only sometimes. I look at it like this though... for the price of the aftermarket alloy shafts you are over half the way to a D60... might as well get it over with now rather then later if you run that big or tire w/ a locker and like to crawl. Just my $.02 worth there though.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I am running the Warn CMoly axles and thoes 297 Ujoints can handel up to a 35" mabie a 36" but I wouldn't go much higher than that with a D44. Mine are very new and only wheeled them 3 times now and so far so good. I have 33"MudRovers now but will soon be 35"SSRs[​IMG]
    Oh and run the hub fuzes too, they are said to work well for saving the 297s.....?? Duno yet!
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
