Alloys
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by XHitman396, Jun 13, 2002.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    i have asked this question numerous times to different people and no one knows the answer. does ANY0NE know what size stock alloy rims are for an '87 K5? i know its either x8 or x7. i need to know cuz i plan on puttn 33's on and can't if they are x7. please help, thanks
    Brett
  2. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    I don't know what they are, but I've got 33x12.50 's on my '87 with the original rims
  3. XHitman396
    May 3, 2002
    620
    are your rims alloys?(do they look like the eagle 589 rims?)
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    They are 15x7. I have a set and the size is stamped on the inside of the rim.
  5. dyeager535
    26,975
    Why can't you go to 33's if you run the 33x10.5's?
  6. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    The ones I have on my truck were just slightly over 7 inches wide. Once they were beadlocked they measure about 7 5/8''. I run a 37 x 13 bogger with no problems. I wouldn't go any wider than that on such a narrow wheel.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I used to have an '87 K5 with the factory alloy wheels. 33x12.50's fit them just fine. /forums/images/icons/cool.gif
  8. XHitman396
    May 3, 2002
    620
    well i rekn i might jus try it then, they wont be low pressure or rock crawlin or anything. so whats the worst that could happen (knock on wood)
    Brett
  9. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    33 12.50's should fit on them.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I used to air mine down to 20 psi up front and 18 in the back when playing in the rocks. That's enough to really soften up the ride, get a good grip on the rocks and not have to worry too much about popping a bead or crunching the wheel. /forums/images/icons/cool.gif
  11. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    my stock 85 ralley rims are 8 or 8.5"...
    J
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Those are ralleys, not alloys. I have 8" ralleys too. The alloys are 7".
    I like the alloys. They're cool looking.
  13. dduckblazer
    dduckblazer Registered Member
    Apr 17, 2002
    64
    Los Angeles
    On a slow trun I can heir my rims making a cliking noise. Why? Centerline rims. Is this rim flex? /forums/images/icons/confused.gif
