Almost done with the motor..Now a TBI ?
Discussion in 'The Garage' started by Stickseler, Jun 18, 2002.
  1. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Were almost done with the motor.. Now tomorow we put the Holley TBI on...
    so the question .. My stock TBI had a spacer .. bout 1-1/2" .. should I put the spacer on with the holleyn?? /forums/images/icons/confused.gif will it work???
  2. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Are you sure its stock?? My '91's TBI unit sits right ontop the manifold. I've heard it go both ways as far as using spacers, some say it promotes better mixing of air/fuel making more power the entire RPM range, some say it adds top end power at the cost of low end and so on. You would probably never notice the difference with or without it so it's your call, if you run through deep water it'll keep your air cleaner that much higher, on the other hand that adds another gasket that might leak later on. Flip a coin I guess /forums/images/icons/laugh.gif By the way, sweet looking motor!
  3. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    We decided the new motor should be stronger than the old one with 225k on it so were gona skip the spacer...probably wouldnt notice it with the new heartbeat anyhow. /forums/images/icons/laugh.gif
    Besides I think the POR Orange added at least 10 HP /forums/images/icons/shocked.gif /forums/images/icons/laugh.gif
