Almost free Zero Rates
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jamber2541, May 21, 2006.
  1. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    picked up some center pins from a local spring shop for $4.00 and had a set of old rear springs laying around. A cutting wheel and half an hour later my
    90 K5 was ready to sit strait. :D
    90 K5 six inch springs all around,
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    post pics
  3. jamber2541
    Apr 10, 2006
    424
    e.p. texas
  4. chopped&bobbed77burb
    chopped&bobbed77burb 1/2 ton status
    Oct 5, 2005
    925
    milwaukie,oregon
    I take the old overload springs and cut off the tapered end with the metal chop saw and use the drillpress to drill a hole in the middle of the cut down spring . It's basically a zero rate/4 degree shim . These get bolted to my front spring packs . I've been doing this for years and have never had a problem with these breaking/cracking . You can always cut out the middle of the over spring and use the factory hole and I think they are about 3/4" thick .
  5. jamber2541
    Apr 10, 2006
    424
    e.p. texas
    thats exactly correct, "cut out the middle of the over spring and use the factory hole and I think they are about 3/4" thick " have done the same thing to friends trucks as well. Thanks for explaining it .
    I should have thought of the old ...keep it simple stupid ...explination from the start
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    nice lookin k5
