alot of play in the driveline?
Discussion in 'The Garage' started by aj_tatted, Jun 10, 2004.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    o.k this has been bothering me now for ahwile, when i get under the truck, i can rotate the driveline about 1 1/2" nin either direction with the truck in park, also when i'm on the highway goin arounf 65-70 and i let off the skinny pedal i hear a horrible sound coming from under (assuming it's the driveline) what could this be? /forums/images/graemlins/dunno.gif
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    who setup your gears?
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Sounds like excessive back lash. Same problem I have every couple of months when my bent housing causes my adjusters to loosen up. That is really a cool sound isn't it?! /forums/images/graemlins/blush.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your adjusters loosen up? Even with those things that hold them?
  5. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yep, apparently it's a common thing when you bend a housing... Everyone I mentioned the problem to went "yep your housings bent" and sure enough when I measured it it was. I have another axle but all that 4 link stuff is welded on and don't feel like redoing it just yet. I'm thinking of acutally cutting the spindles off and making new ones. The right side spindle is what's bent a little.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The answer to the excessive slop is in your signature... "Detroit Lockers". /forums/images/graemlins/eek.gif
    If you want to know more about why a Detroit Locker does that, click the link in my sig, then click on "Tech Articles" on the left of the page. On the tech page you'll find an exhaustive paper on lockers. /forums/images/graemlins/thumb.gif
  7. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Does that article go for limited slips too becuase that is what is in those axles true trac limited slips.
