alright, center bolt intake on older heads
Discussion in 'The Garage' started by sled_dog, Sep 26, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    so who has actually done this swap? I think I'm puting the 355 I have in my K5 into my 89 Burb now. But I want to get a 87+ Ebrock performer since it has the rear water crossover I need for my heater setup. So who has modified a 87+ intake to fit older heads? I know people say oh just slot them, but I've never seen it done or talked to someone who has.
  2. bleedchevy
    bleedchevy Registered Member
    Nov 4, 2003
    54
    Oakley, MI
    i sloted the center bolts, then filled the gaps with rvt sealent, works all right, Holly makes adapter plates so you retain your tbi on older heads, and keep a better seal between the intake and heads
  3. S-30
    S-30 Registered Member
    Feb 27, 2003
    23
    Minnesota
    i just did it about 1 month ago. i had an older 350 that was built up really nice. about 350HP with a carb. i just used a die grinder and sloted the bolt holes out and tried the spot face the intake to match the new angle. the bolts bent a little when i tightened them down put i have had no trouble yet. make sure you use gaskets for a tbi motor though or the coolant will not flow right.
