Alright lets see your lighting setup
Discussion in 'The Garage' started by FarmRig, Jul 7, 2006.
  1. FarmRig
    FarmRig Guest
    Thinking about mounting some reverse lights on my k10 just wanted to see some pics of where everyone is running lights. Upfront and on the back. Thanks
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    My back up lights...
    Rene
  3. FarmRig
    FarmRig Guest
    That looks good. But i have a stocker bumper. Looks like i gotta make one sometime.... Thanks
  4. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    Do you have a hard top? Do like an under cover cop truck. Mount them off the last bolt; use a flat bar stock and drill two holes in it one for the tops bolt and one for the lights bolt. [o _ _ o] <-- like that from the rear of truck.
  5. FarmRig
    FarmRig Guest
    I actually have a k10. Good idear though Metrodps.
  6. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I still have the ones that came on it already from the PO. On my 77 K10 I had one mounted on the center portion of a two lid tool box, facing backwards.
    I'll see if I can find/post a pic of my K5's BU lights
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Not to hijack,but how'd did you guys wire 'em? I'm about to wire up for mine, and I can't decide if I should put 'em on a three-way switch (on-on with reverse-off) or just a manual 2 way switch (on-off not wired into the reverse switch on the tranny)? Any real world pro's or cons to a particular way?
  8. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    I would go with just a switch to turn on off that way if you need light to work on another truck behind you you can switch on. Or you get a grass pole behind you with brights on going down the road BAM!!! they get the point real fast.
  9. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    The PO wired mine into the reverse lights, they come on when I put it in R. They work great too.. makes a big difference compared to my old K5. I probably would have just wired them to a switch, so I could use them whenever I wanted, .. but I think that I would be to lazy to use them backing up .. lol. This way they're always used.
  10. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I run these little halogen lights bolted to my rear bumper. I ran a wire to the bupers to ground them (same spot as the tail lights ground at) and then ran one positive wire along the frame under the cab where it pops in then is run up to the fuse box. I have a fuse in line so I just hard wired it into one of the open "hot" spots in the box. I put an in line switch in and mounted it on my dash. It lights up when I turn the switch on so it makes it easy to tell what their up to. I'll get a shot of the switch tomorrow for ya'.
    -Avery
  11. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Here's mine. 6" Hella spot. Hooked up to reverse circuit, but still now workie. I think I have some gremlins due to a trailer lighting socket.:mad:
  12. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Rear facing, Wired on a relay setup and not hooked to Rev.
  13. FarmRig
    FarmRig Guest
    Guys is there anyway you could post them or send them to me email. I cant see them when they are attached like that. Thank you very much though got lots of ideas going but i wana know more bout this lights on the lid of the tool box thanks y'all
