Alright MSD experts I need help!!
Discussion in 'The Garage' started by TWISTEDJACK, Jul 31, 2005.
  1. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I am almost done with swaping my drivetrain over from my truck to my K5. I can't get the ignition to fire. All of these parts were installed on the same motor and with the same distibutor and same ignition box. I have checked the wiring several times. I am getting 12 volts while cranking. The coil gets very hot. I already burn up one coil. What do you think is the problem?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    Call MSD, their tech support is awesome and they know thier products much better than any of us will.
  3. corey6969
    corey6969 Registered Member
    Jul 23, 2004
    58
    ND
    which ignition box do you have? I have the 6al and it says the coil wont be charged if just the key is turned on. See if it gets hot just turning the key on, if it does ide hafta say its something with the box, or maby a wiring problem :D . But im sure the nice MSD people would help you much more then i could.
  4. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Hot coil
    Sounds like you've got some wires crossed somewhere, and the coil is shorting to ground. www.msdignition.com has wiring diagrams online to make sure you got everything going where it needs to be.
  5. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Thanks I spent 5 minutes on the phone and I should have it fixed tonight.
