alright what has the 14 bolt disk swap cost you?
Discussion in 'The Garage' started by supersize75, Jan 7, 2003.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    Did a search and more info is needed as well as a write up as someone else mentioned earlier. Whoi has done it and what all do ya need to do it? So far the cheapest place for brackets is 55 bucks and need to know the rest thats involved, I just got my 14 bolt ff today. And since the brakes are in a box all mixed up might as well swich /forums/images/graemlins/grin.gif
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Well...
    I have yet to do it but so far...
    No wait.... Buy a membership there's a KILLER article in the members area...
    I have the rotors and the calipers already so I just need the backing plates... and i already have the hoses too /forums/images/graemlins/smile.gif /forums/images/graemlins/thumb.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Let's see...
    Derbinator brackets - $100
    Calipers - I had a set, but about $20 each for non e-brake ones
    Rotors - $36 each
    Short rubber brake lines - $18 each, I posted a part number a while back, you can probably find it if you do a search.
    New hard lines - $8
    Being able to actually stop this beast - Priceless. /forums/images/graemlins/thumb.gif
    Total cost - $238, I paid about $198 out of pocket. I could have done it for less, but I opted for new parts. Going with the e-brake calipers will add around $200 to the price, plus whatever the e-brake cables cost.
    </font color>
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    Brackets (A-tron) ... $90
    Rotors...robbed from old D44 $0
    Calipers...robbed from old D44 $0
    Rubber lines...robbed from old D44 $0
    Hard lines rebent to suit
    Brake fluid...$10
    Total cost $100
    Rene
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Brackets were $65
    Calipers $24 each
    Pads $14 set
    Hoses $18 each
    Roters $29 each
    So around $225 or so.
  6. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Brackets= 90$
    Calipers= free
    Hoses= free cmae with calipers
    pads= 15$
    rotors= 25$ each
    Hub seals= 5$ each
    Studs= 2$ each
    197$ total
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    if you want a e brake or need one it will be 78 dollars for the 78 cadi calipers apiece 15 dollars for pads and i think inline tube makes custom ebrake cables for whatever you need.i have to call them and check price still.then the same for what everyone else said.
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Brackets (I made them) $50.00
    Rotors $65.00
    Calipers (ford w/e-brakes,pads,hoses and cables) $55.00
    Total= $170.00
  9. supersize75
    Sep 27, 2002
    2,638
    thanks for all the reply's
    and what ford calipers will work?
  10. TONYP
    Aug 13, 2002
    2,116
    so cal
    I used the ford t-bird 86-89
  11. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    The brake pads look awfully thin. Did you have to cut down pads to fit over rotor? Would these calipers fit the Atron brackets?
    tom
  12. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    Our brackets are designed to be used with either the GM or Cadillac calipers and rotors.
  13. TONYP
    Aug 13, 2002
    2,116
    so cal
    Thats just the caliper bracket, the calipers not installed on it yet..
  14. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Lets see...
    Brackets...$60
    Calipers...$25
    New Pads..$35
    New Rotors...$70
    Misc...$50 (I ran a new hard line for the rear axle and some other stuff)
    e-brake....$800 (it did come with a nice 1-ton cv driveshaft )
    Total...$1040 /forums/images/graemlins/shocked.gif /forums/images/graemlins/crazy.gif
    All that because I didn't want to replace the drums that had been warn down by shoes warn down to the rivits. /forums/images/graemlins/1zhelp.gif
  15. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    has anyone got an idea of cost to totally rebuild a 14 bolt FF's drum brakes?
  16. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    14-bolt FF Drum Rebuild
    I spent about $100 getting the drums turned, new seals, all new hardware &amp; springs, new shoes, etc. But this was w/ NAPA &amp; I'll get $25 (now down to $75 total) core on the old 13x2.5 pads.
    Thanks!
    Doc
  17. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    FF14- $200
    brackets from Derbinator- $100
    reman. calipers from Autozone- 2@ $15
    pads (I had them already)- about $15
    braided stainless hoses from TSM- $50 (Autozone wanted
    $28.50 each for factory rubber)
    rotors from Advance buy one/get one -$27
  18. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    That was one of the things that promped me to go dics.
    IIRC the drums were $130 each!
  19. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I bout my brackets for $55
    Caddilac Calipers for $22 each (junkyard - lucky find, freshly rebuilt)
    3/4 ton front rotors $30 each
    Used my Dana60 rubber brake lines (had extended for the front already)
    New hard brake lines on the axle (just because) $15
    So about $174. I spent more on all of it at the time becuase I wanted to replace all the bearings and seals while I had it apart. I don't regret it at all!
  20. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Rotors $60
    Brackets $60
    Calipers $0
    Pads $0
    Hoses $0
    Bolts $5.68
    So, $125.68 total
