alt help please
Discussion in 'The Garage' started by clarkjw24, Mar 24, 2005.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Well I drove my rig to work today and now the batterys dead. I've recently did the tbi swap and after close inspection, I don't believe that the alt is hooked up right. I have no charging system. Someone plz help me so I can get home tonight. Here is a pict of what I have. Shouldn't there be a wire coming from the back lug to the big lug on the starter? The red wire from the plug was only long enough and lugged to reach the post on the back of the alt. Thanks in advance.
  2. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    It should work...
    Thats not how the factory wired it--but when adapting a GM altentor to a tractor or other equipment,thats how we wired them up,and they always charged..
    Check for power at the brown wire with engine running,with a test light--it should have 12v there-(and so should the red wire!)-if its dead,it wont charge--it needs 12v to "excite" the feild coils in the altenator to make it charge--it takes power to make power..
    If the brown wire has no juice,its probably broken or corroded somwhere in the harness,or where it goes into the fuse box--you can run a wire from the battery positive terminal to the brown wire right at the altenator plug,you will hear it "kick in" and charge if the brown wire being dead is the problem...a quick test to see if its charging is to hold a screwdriver near the rear bearing cap in the center of the altenator--a strong magnetic "pull" indicates its charging...
    If both wires have power,then its likely the altenator or regulator,diode trio,or rectifier bridge inside it is junk--time for another altenator,or rebiuld it....:crazy: --Hope this helps....:grin:
  3. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Got her charging now. Thanks
    :xmas:
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    screwdriver or similar object stuck near shaft bearing on backside of alt with engine running is great way to test for alt field charging
    good luck
