Alt. overcharging?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by seslick77, Oct 4, 2002.
  1. seslick77
    seslick77 1/2 ton status
    Jan 27, 2002
    220
    Colorado Springs, Colorado
    Volt meter is reading in the red on the high side... Is the Alternator overcharging? Battery reads fine...just jumps up when its running.
    Sam /forums/images/graemlins/k5.gif
  2. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Should be around 12 volts with your truck off, if it's charging right it'll jump up when it's running. Man I wish I had your problems /forums/images/graemlins/smile.gif Do you have access to a DMM? If it's charging about 14.5 volts that might be a problem, but I'm not sure.
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Might be the voltage regulator, not cutting of at higher RPMs. I have the opposite problem, low when driving, normal at idel? J
  4. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    did you ever figure out what was causing this problem????????
    ric
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    A good battery should have between 12.2 and 12.6 Volts, even seen a few at 13 volts.
    When the system is charging, you should have a max of 14.4, 14.5 volts. And a min 13.5 volts.
    Any thing beyond these numbers means your regulator is bad.
    Anything below these number means your alternator isn't up to the load you have.
  6. seslick77
    Jan 27, 2002
    220
    Yep problem was fixed! Replaced the regulator and fixed it for 2 days then it was undercharging!! /forums/images/graemlins/confused.gif Had it tested and alt. was shot. Thats when I realized that it was my fault it died.... The night I finally got my Blazer running I decided to go on a little test drive. 11 at night no plates, no insurance, just figure I take it around the block... Got two blocks at she dies!! No motor, no lights, notta!! Pulled over and noticed smoke rolling out of the hood. First instinct was oh sh*t I locked up my new motor!! Popped the hood and the batt. cables are on fire!! Thats when I realized I ran the damn pos. cable between the frame and the manifold. She got hot and melted the covering off and shorted out on the exhaust manifold... Well long story short, fried 2 new cables, alt. and regulator, and welded the starter to itself!! /forums/images/graemlins/shocked.gif Won't do that again!! /forums/images/graemlins/rolleyes.gif I have a problem with accidentally setting my vehicles on fire... And I'm a damn fireman....go figure!! /forums/images/graemlins/rolleyes.gif
  7. BOWTIE
    Dec 28, 2000
    2,018
    thanks, /forums/images/graemlins/thumb.gif
    i'm having the same problem.. i'm going to take it and have it tested and see what the deal is......
    ric
