Altas T/C ?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Donovan, May 12, 2001.
  1. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    If a person like myself was to build a Transfer Case like the Atlas T/C what gear ratio would you put into it. It would be a 2 speed setup. Why can't you run a Atlas in a Fullsize? What breaks on them? Just looking for some information. Thanks guys.
    Donovan
    <A target="_blank" HREF=http://www.rustbucket.coloradok5.com>http://www.rustbucket.coloradok5.com</A>
    Bigger is Better
  2. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    Why cant you run an atlas in a fullsize? Who told you that it cant be done?
    '78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt rear w/ Detroit
    <A target="_blank" HREF=http://65.11.18.114>http://65.11.18.114</A>
  3. timebomb1602
    timebomb1602 1/2 ton status
    Mar 30, 2001
    138
    hudsonville, MI
    all the tech artices say it isn't strong enough to take on full size wieght and power.
    <font color=red>1991 GMC Jimmy 350tbi 3.42</font color=red>[​IMG]
  4. xtreme_wlr
    Mar 22, 2001
    103
    San Diego, CA
    Well they get put behind V8s all the time. I think they are supposed to be able to handle up to 750 lbs/ft of torque. Alot of the jeeps they get thrown into arent all that light either. Should work just fine in a fullsize with a small block.
  5. xtreme_wlr
    Mar 22, 2001
    103
    San Diego, CA
    Got this from the Advanced adapters site:
    The Atlas has been tested and proven to handle 900 plus ft./lbs
    <A target="_blank" HREF=http://www.atlas-tc.com/general/general.html>http://www.atlas-tc.com/general/general.html</A>
  6. aaaaggh
    aaaaggh 1/2 ton status
    May 4, 2001
    161
    birmingham alabama cause there no ham like birming
    the atlas was redesigned a couple years ago. its the old ones you cant use in a full size the new ones are fine. actually either of them will be stonger than just about anything stock fullsize or not.
    friends romans countrymen, lend me some parts
  7. Donovan
    524
    Arvada, CO
    Well there is a guy on this board that has a Atlas in his blazer and it seems to be working fine. I had a chance to look at the insides of a Atlas at High Country 4x4 in Denver and I was not at all impressed on the unit. Don't get me wrong, it is very nicely made, but the gears are way to small for a fullsize blazer or truck. The width of the gears are only .900" wide. Look at a NP205 and the output gear is 1.000" wide,but remember that you are twice as low as a 205. So this is why I don't think that you should use them. I just think a better case can be built. I am going to try and do it. It will have one large ass output shaft. So what gear ratio do you guys like or would like to have.
    Donovan
    Bigger is Better
  8. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    Approx. 2.5 and 5.0 would be nice.
    <font color=green>Joe Angelicchio
    86 Jimmy 4+3, 35-&gt;39.5 tires,4spd
    </font color=green>
    [​IMG][​IMG]
  9. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    You might want to talk to Dblazer I think he's running an Atlas II in his K5. He wheels his blazer pretty hard and it seems to hold up.
    Ric
