Alternatives to useing a tennis ball
Discussion in 'Communication (CB | GPS | HAM)' started by not4show, Jun 21, 2001.
  1. not4show
    not4show 1/2 ton status
    Apr 24, 2001
    280
    Alabama
    I am going to put a 102" whip antenna on my truck, but I need to put something around it to keep it from scratching my truck. I don't really want to use a tennis ball though. Anybody have any suggestions? Thanks.
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Here's an idea. I'm assuming you're planning on mounting the antenna on the rear bumper...
    Get a flat sheet of plexiglass, let's say 3" x 6". Hardware store should carry it. Drill a 1/2" hole for the antenna whip to pass through. Leave at least 1" of material around the hole for support. Pass the whip through the hole, and sandwich the plexiglass between the top and the bedside. Presto! Instant non-conductive antenna brace.
    <font color=red>Click those banners and help support CK5!!<font color=black>
    [​IMG] Semper Maintenance!
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Someone makes a really trick little plastic spacer deal - it looped over the antenna and was held to the body with doublesided tape. I've seen them on several J**ps and on Sheriff's Blazers/Broncos with CB's.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  4. scrapmetal
    scrapmetal 1/2 ton status
    Jan 22, 2001
    100
    Rathdrum ,ID
    Its called a bent thing around the end of the thingy on the whip, [censored] anyone can make one, just go to a hardware store, and tell ya need some light gauge steel strap, get home drill a hole for the rope and bend the other end to just slip on the end of the whip,, lessoned learned,,
    Never been stuck, just temporarily delayed.
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    JACK's head from the IN THE BOX...
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  6. not4show
    Apr 24, 2001
    280
    Alabama
    Thanks for info guys. I'll probably mount it this weekend.
  7. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    my 102" whip is mounted on my rear quarter-panel, only when i'm really movin' off-road does it bang around and it really doesn't hurt the hard or soft tops.... but i do like the plexy idea and will prob use it when the hard top goes back on come winter....thanks!
    peace.
    HAYDUKE
    Insured By COLT, Policy #.357M
    <A target="_blank" HREF=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</A>
  8. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    the other advantage, is that a vertical antenna has the best reception ( I believe... correct me if I;m too blatantly wrong) this is why sometimes you see the fiberglas whip antennas on semi's angled slightly forward... when they hit highway speeds, the antennas are generaly about vertical.
    -Rich
    1977 C20 suburban
    454/400 trailering Special
    1973 K20 suburban
    350/350/np205
    Atlantic 442 Steam locomotive
    Daisy Mt Railroad
  9. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    you are totally correct. The signal from a cb antenna works kind of like when you throw a rock into a pond. It gives of a cirular riple that works it's way through the pond. The signal is the same, if you point is down it wint work as well!!!
    http://autotronixcaraudio.com
  10. 83blazer
    83blazer Registered Member
    Jul 12, 2001
    48
    Memphis,TN
    insted of useing a tennis ball try other balls like baseballs basketball bowling balls itll look cool
    HOOK IT TO WHAT YA DONT WANT
  11. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Racquet Ball?
    Why do people keep calling it a Bronco!!!!! [​IMG]
  12. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    A guy used a part from his sons toy that was a plastic heliacopter roter........
    C'moe
    Kill Roy was here!
  13. SubYuman
    SubYuman 1/2 ton status
    Oct 13, 2001
    246
    Edwards AFB, Ca
    Use a small piece of plastic or aluminum to shim the antenna out slightly at the spring.... used to do it on our Hummers for HF antennas that were 12' long and HAD to to work....look at what your antennna does when you are doing what you do and eye ball the right size for your application....
  14. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Have you thought of a door gaurd plastic.... it should go around the antenna no problem heat it up a little and finish molding it around the antenna....
    C'moe
    Kill Roy was here!
