Alternator Amps Produced and Drawn
Discussion in 'The Garage' started by prossett, Apr 22, 2006.
  1. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    I read from a search that the stock 83 Jimmy petrol engine alternator produces just 37 amps! Is this correct?
    Where do the amps go with a stock set-up? I also need to add the draw from three 55W lights, so 13.75 amps.
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Same in '85, 37 amp alt was standard, 66 amp was optional. With standard lights and whatnot, this was plenty. However, with high-current accessories, such as one or more electric cooling fans, huge stereo amps, hi-wattage driving lights, and so forth, it's easy to draw more than you make with all that non-standard stuff running.
  3. dyeager535
    26,980
    Draw would essentially have been the heater blower motor, radio, ignition system, and lights. That's base only of course.
    Heavy duty heater, AC, etc. would likely have resulted in a higher rated alternator.
    If the alternator is stock, Amp rating is stamped on the alternator case. Not always visible with the alternator installed IIRC.
  4. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    time for a larger alt
    lots were 63 or 82 and others
    were billions of different alt amp ratings over the years in stock factory form
    can have a local battery or electric motor shop build one up for ya
