alternator charge wire... how big???
Discussion in 'The Garage' started by RootBreaker, Feb 25, 2007.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Ok so my truck has a 63A alt in it... I may upgrade it eventually to a 80A just to do it.. I did at one point get ready to do the 140A pontiac Transport Alt upgrade... still may do it in the future but then need a new isolator....
    anyway... what size wire should I be running from the back of the alternator to the isolator? 12 gauge? I have a 2 gauge I could use but too big will not be a good thing.....
    also I need to run another wire from under the hood back to the bed... right behind the cab... same size? or a bit bigger due to about 10' length?
    please lemme know as i am getting ready to goto the parts store...... :crazy:
  2. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    bigger IS always better, well, alot of the time..... :wink1:
    other than bulkiness, size constraints... minimum wire gauge is a function of amps drawn over distance...
    For a stockish replatement, I'd run 10, even 8 if I was gonna be working the alternator hard... Personally, I'm running 4...
    For a rear feed, I'd up that a couple to an 8 or 6...
    check the chart at the bottom of this page..
    http://www.rbeelectronics.com/wtable.htm
  3. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
  4. runamok151
    runamok151 1 ton status Premium Member
    Oct 24, 2005
    12,542
    1,455
    the armpit of the east coast, 08046
    aren't you done with all those fancy switches yet?
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    I got 3 in....
    didnt ya see that post?
    http://coloradok5.com/forums/showthread.php?t=198369
    anyway...
    I bought a roll of 10gauge wire today... and terminal ends.. gonna do some each night this week.. hopefully I can get the wiring done by friday so I can start on the spring bracket push back.....
