Alternator dilema, what should I do?
Discussion in 'The Garage' started by Bubba Ray Boudreaux, Jun 7, 2003.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Got a 140 amp for a '94 Pontiac Trans Sport, doesn't bolt right up......
    What should I do?
    1. Break out the welder and grinder and 1.5" square tubing and attempt to build an extension onto my current bracket?
    2. See if I can't find a custom bracket aftermarket?
    3. Take it back and see if the '86 Buick Park Avenue 120 amp alternator bolts right up?
    Here's how close the Pontiac alt. is......My stock bracket needs to extend approximately 2" further out to be able bolt up the top half of the alternator. This is as close as it can get without the alt. fan rubbing the bracket.
    One last thing....The pulley on the Pontiac is 5 groove, I have 4 groove. Swap pulleys or can a 4 groove belt properly run the alternator.
  2. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    no question here, break out the welder and fab up something. /forums/images/graemlins/grin.gif
    i would think as long as the grooves themselves line up. that is if you draw a sight line down the alt pully and the others, do they match. if the fifth groove is out/in board of the rest what do they (the grooves on the belt /forums/images/graemlins/wink.gif) care if there are ten grooves on the pully.. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    The more I think about, the more I want to do it. I think I have enough 3/16th" plate sitting around to cut up and add an extension. Think I'll go down to pick and pull this week to find another bracket so I can work on this.
  4. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    buy a new alternater. how much is it where you live? i have one i'll send you /forums/images/graemlins/k5.gif
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Fab, and swap the pulley....Then check that new question on T.B. /forums/images/graemlins/thumb.gif
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Well okay, this is a new alternator. So if ya want to be so helpful, tell me which application will bolt right up to my '87 SBC that will kick out about 130 amps.............That is cheaper than the $100 that I'm spending on this 140 amp unit.
