Alternator identification
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by deothrwhtmt, Apr 26, 2001.
  1. deothrwhtmt
    deothrwhtmt Registered Member
    Feb 24, 2001
    61
    Maryland
    Guys thanks for the input on the rear to front spring notion. I have an 1988( late year prod.) Jimmy with 350 TBI. What series alternator, CS-xxx?, do I have?
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Dunno dude, It should be stamped on the front half of the alt. somewhere on top, behind the alt fan.
    Twiztid
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The 130 or 144 are the diameter of the stator in mm. I think that the cs130 has 3 case bolts (holding both of the case halves together) and the cs144 has 4. I just did a search on google using the # on the case and came up with alot of info. If it is a cs130 get an Iceberg conversion kit for it <A target="_blank" HREF=http://www.alternatorparts.com/iceberg.htm>http://www.alternatorparts.com/iceberg.htm</A> to make it last alot longer.
    '71 Blazer CST with alot of rust
