alternator mods
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Apr 25, 2001.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    OK, I am going to order the CS144 140 Amp alternator for my 85. What is involved in the swap? I know I will have to fab a bracket for mounting... but what else is there? Like a connector? Will it plug in or will I have to cut the end and splice mine on? Also, what about the wiring that is there? Is it heavy enough to handle the increased Amps? Fuses? Etc.
    Thanks.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
  2. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I installed the factory large case 180A (CS144 I think) altenator on my 454 and I just needed to trim the bracket. I measured the difference in the distance from the mounting ear to the adjusting ear and trimed that much off of the factory bracket. I then took a jigsaw to cut the slot for the adjusting ear. You can't tell the difference by looking at the bracket. I had an altenator shop make a connector so that the altenator works just like the factory one did.
    The factory wiring will not support 140 amps. I ran an 8 gauge cable to the distribution block on the firewall and a 4 gauge wire to the battery. The 8 guage wire will carry 100 amps for a short period of time and 75 amps continuious. I suppose you could double the 8 gauge wire but then you still need to get the power to your battery and winch.
  3. Thumper
    1,582
    Alberta Canada
    Has anyone done this? Id appreciate any help.
    Thanks.
    Mike
    85 Fullsize Jimmy
