Alternator Mystery... or...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Apr 24, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK... I'm stumped... I thought I had a slipping belt... The alternator belt was howlin something terrible... I took the old belt off.. nearly broken through... I put a new belt on and the problem seemed to cure it self... i did tighten it correctly...
    Well the squeel is back... It is tight... I know it's the damn alternator... If I am at a light and roll my windows down, electric windows, the voltage guage dropd from 14 to 12 and the howel begins again... If I am driving down the road and I roll the windows down and hold the switches down... the howeling starts... If i start it on a cold morning, and turn the fan on too soon the howeling starts... it seems that the alternator is not doing something right... I wanna get some input before I put a new alternator in her... not wanting to spend the money... it's a easy 10 minute job but... I'm lazy...
    [​IMG]See me at <A target="_blank" HREF=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</A>
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Check pulley and belt alignment with your current set up to see if they are running true. If so, you got a alternator that is trying to give up the ghost. It's warning you and will fail when you need it most...dark foggy night in the backwoods...sounds like a Stephen King novel in the making.
  3. 89k5blazr
    89k5blazr Registered Member
    Apr 24, 2001
    48
    The Garden State
    i would have to say check the alignment of the pully's. But when you say it squeels under load my guess is that it could be the bearings in the alternator (which make a similar squeel) or you are using more amps then the alternator can put out. Try replacing it. I had a similar problem but it was fixed when the alternator puked.... i replaced and havent had a problem. I bought a lifetime warranty rebuilt one for like $40 with a $15 core charge which i got back after i yanked the old one.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would check the bearings also try having a friend roll your windows up and down to make the noise and spray the belt not the pully with wd-40 and see if it stops if yes then it is a belt issue if no then it should be a bearing issue
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  5. reddog64
    Nov 9, 2000
    3,325
    the bearing does get replaced on the new alternator.... or am I smoking crack.... will the alternator off the 454 laying in the back work??? same year...
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    make sure you go with a good rebuilt manufacture. some rebuilders only replace the 'worn' parts. That is olny those that are not to specs.
    my 2 centavos...
    ARQ.
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes the bearings get replaced with a new alternator but im not sure if the one out of the 454 would work or not. im sure someone on this site dose though[​IMG]
  8. reddog64
    Nov 9, 2000
    3,325
    Anybody know if the alternator of my spare 454 will work on the 350 in the blazer???
  9. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> I've got the same problem on mine , It squeels something feirce upon acceleration or even revving it up...... It's a new engine and I just put a new belt on, then when I had it timed I was told the belt was shot. They replaced it and now it squeels again............. do you think it's an alignment issue ? If so, how do I get it to run true ?
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  10. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    If the alternator from the 454 fits the bracket, and the wire connectors are the same, it should work.
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  11. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    I would remove the belt and check the bearing real quick....however...a little known fact is that a faulty DIODE in the diode tree (3) can howl like a loose belt! Usually the diode fails and each diode is worth a 3rd of your charging capacity...which shows a no charge condition...i think if you put an amp meter across her you will find a definate problem.
    Azblazer
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
  12. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Lifetime warranty doesn't really mean anything if you have to replace it 8 or 10 times. Spend the extra money, and buy quality. GOPHERKILLER
  13. reddog64
    Nov 9, 2000
    3,325
    mine only squeels if i roll down both windows... liek if I put a good strain on it.. I have no extra electrical accessories... no stereo or nothin... I can watch the guage go from 14 volts to 11 volts really fast... when it hits 11 volts it squeals... I tightened it today.. and no it wasnt it... I guess i'll pull it off tomorrow and get it tested
  14. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Had a similar problem on mine and it turned out the tensioner pulley bearing was on it's way out. The extra drag of the of the bearings breaking down and welding to each other was slowing everything down causing the alternator to not charge as well. Also made it squeal intermittently. But then again, my alternator caught fire a month later...
    Why do people keep calling it a Bronco!!!!! [​IMG]
