Alternator Not charging....Voltage regulator ??
Discussion in 'The Garage' started by steedalx, Nov 13, 2004.
  1. steedalx
    steedalx 1/2 ton status
    Dec 19, 2003
    142
    Chattanooga, TN
    OK....I got all my other issues resolved except one...the alternator is not charging the battery. I pulled the wiring harness out of the voltage regulator and with a wire ran a jump from the red wire(#2) to the dark blue wire(#4) on the harness.....the alternator then begins to charge. So I figured a bad regulator so I got one today at the parts store. Nope still not charging with the new regulator. Can someone give me something else to try? Thanks
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    How do you know its charging?
    Do you have some sorta external regulator? All the gm ones I've dealt with are always internal. ? Odd that you were able to jump those as well- I've gotten some seriously rediculous voltages out of those two pins when the regulators fry....
  3. steedalx
    Dec 19, 2003
    142
    Chattanooga, TN
    I have a tester hooked up to the battery it shows the alternator is not charging at all when the harness is hooked to the voltage regulator....and yes it has an external voltage regulator.
  4. steedalx
    Dec 19, 2003
    142
    Chattanooga, TN
  5. steedalx
    Dec 19, 2003
    142
    Chattanooga, TN
    Ok I posted a picture of the regulator. The only piece that I did not replace was the round, cylinder shaped thing that plugged into the bottom of the regulator. Does anybody kow what this is?
  6. steedalx
    Dec 19, 2003
    142
    Chattanooga, TN
    Ok if this is going to be a huge pain I assume I could upgrade to an internally regulated alternator?? If so does anybody have a model #....Thanks
