alternator options? *with update*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by greg83k5, Feb 8, 2002.
  1. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    i went to pep boys and got the alternator rebuild kit- it came with brushes, diode trio, regulator, and bearing. 13 bucks. a new 90 amp was like 120, so that was good.....
    after disassembling the alternator, it was obvious why it quit charging- the brushes were crapped out....
    the instructions made it a snap, and now it's ready to go. i would HIGHLY recommend this course of action as opposed to going to get another one........
    oh yeah, the allen head/wrench method doesen't work so well on the 86 12si flat belt alternator, but i zapped it with the impact and it came right off, hey i was replacing the bearing anyway....
    aw yeah. 90 amps. thirteen bucks.... thank you....
    greg<P ID="edit"><FONT class="small">Edited by greg83k5 on 02/10/02 01:38 AM.</FONT></P>
  2. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    Re: alternator options?
    the pulleys should be intercangable, just unbolt the big nut on the fron, and any alternator can be clocked to whatever you want, the only problem is does it mount the same? I dont know.
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  3. greg83k5
    Nov 2, 2001
    230
    ttt..... i see this post got lost....... its a moneysaver so ill give it a boost!!
    * keep the greasy side down *
  4. Re: alternator options?
    so you can increase your amp output with the rebuild? you don't have to buy one that is the same as you existing output? if that is the case couldn't a guy rebuild it to be 100 + amps?
    <font color=blue>You think you're excited, feel my nipples!
    </font color=blue>
  5. greg83k5
    Nov 2, 2001
    230
    i'm sorry i shoulda clarified!!
    i had a 65 and a 90 amp unit. i rebuilt the 90 amp unit, and swapped pulleys from the 65 amp one that was on the truck to begin with.....
    any alternator shop, if you live in an area large enough to have one, should be able to rewind your alt. to crank out some extra amperage....
    greg ( ssorry for the confusion!!))
  6. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    I thought about rebulding mine originally but what I needed from that alternator were beyond typicl rebuilds. So I went on ebay and purchased a customized 190 amp alternator with a idle kicker in it and it works quite well
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
  7. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    OK I'll bite. What's an idle kicker? How does it work? Who makes it?
    Real trucks don't have spark plugs!
  8. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    190 amps???? WOW, that's a lot of juice!!!![​IMG]
    I see in your pic that your run some off-road lights, but what else does your rig have that requires that much power?? Just curious......
    Is there any risk of overloading your electrical system with an alternator that powerful?
    <font color=red>DIGGING AND DIGGING AND DIGGING</font color=red>
  9. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    um well their is the gps laptop navigation system. full on board air, 6000 watt sound system 1000 watt power inverter um should I go on ?
  10. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    yes continue
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
