Alternator or voltage regulator
Discussion in 'The Garage' started by divorced, Nov 24, 2006.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Ok guys, It's not a Chevy but maybe someone can help....
    1976 F350 2wd with a 390.
    I tested the voltage at my battery and it's the same with the truck running or turned off. How can I tell if it is a bad alternator or just a bad voltage regulator?
    (It has an external regulator)
  2. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    Sounds like the alternator.. Most voltage regulator failures I've seen allow too much voltage...
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the way i always test for a bad alternator is to start it and then remove a battery terminal. if it quits, the alternator is bad.
    it doesn't sound like a voltage regulator though, like ryoken said, they usually put out too much voltage.
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Does it have the solid state regulator, or the old points style? The points style, you can remove the cover, file the points and adjust them. I can't remember which ones, but there are two wires you can jump to make the alt go full chaarge, bypassing the reg.
  5. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    here's how..
    I would not try running the truck with the battery cable off to see if its charging--you can blow diodes doing that!...a safer crude test ,lacking a voltmeter, can be done with a screwdriver--hold it near the rear bearing in the altenator--if its charging,it will attract the screwdriver strongly to the case (while engine is running:rolleyes: ).....
    To test the regulator,unplug it,and either use a jumper tool designed for this purpose,or make your own jumper wire with solderless connectors that fit the harness you unplugged to the regulator...jump the terminals "A+" or "Batt" to the "F" or Field terminal together,(they are marked on the regulator where the harness plugs onto it) and run the motor slowly--if the alternator lamp goes out,or the voltmeter shows an increase in voltage,then the regulator is faulty,not the alternator...:crazy:
    On older Fords like this you can buy a solid state transistorized regulator,or a cheaper mechanical one..I prefer the solid state one,its sealed and cant get corrosion inside,a big feature here in the "salt-east"...:doah: ..We put a Delco 10SI alternator on our '70 F350 ramp truck with a 390 in it when the original motorcraft one croaked..didn't take much modification either!.:crazy:
  6. divorced
    Jul 20, 2004
    5,115
    It was a bad alternator. I replaced it and the regulator and all is well now. Thanks for the help!:waytogo:
