Alternator question!
Discussion in 'The Garage' started by dallassnowman, Apr 10, 2004.
  1. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    Just replaced alternator and all belts, after the old one died. And now while at idle with the ac on, my volts drop low, almost to the line above the red mark. I replaced with an orginal replacement alt....
    My question is..."Is this normal and is this ok or good???" All I have is an aftermarket radio. While driving it sits well above 13 volts.
    Its a 82 blazer with a 6.2 diesel. /forums/images/graemlins/k5.gif /forums/images/graemlins/confused.gif
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Make absolute sure you have all the wires connected on the alt. I did this once and forgot the plug. If this doesn't fix it, i would take the truck somewhere like Autozone and have the charging system checked. Shouldn't drop that low IMO.
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    If your battery died(usually thats how we find out the alts out /forums/images/graemlins/doah.gif), that may be the problem.
  4. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Yea I agree. Sounds like the sense wire isn't connected or broken or somethin.
    Good luck to y'all in the future.
    Allan
  5. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    ok, ill check it out in the morning, thanks
