Alternator question
Discussion in 'The Garage' started by bad_bo_ti, May 30, 2004.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    I am wanting to upgrade my truck to a serpentine setup but i think the only alt. that will fit are a 1 wire mine has 2 what would need to be done to correct this. also i know someone has told me before but why does one have 1 and the other have 2? thanks, chris
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    aftermarket serpentine setup, or factory style?
  3. bad_bo_ti
    1,027
    OhiO
    factory, my bad /forums/images/graemlins/thumb.gif i got a donor vehicle lined up all i need to buy is the alt and the water pump and a different fan.
  4. dyeager535
    26,977
    Monte Carlos with V8's (for sure) starting around '85 went with a semi-serpentine setup, alternator being one that is serpentine. Still the same style wiring.
    Trucks went with that system for awhile, but I'm not sure of the years either.
    I'm assuming though, that the semi-serpentine alternator will work with a full serpentine setup. I'm 99% sure it will, but I've never dealt with the full setup.
  5. muddbudd72
    muddbudd72 Registered Member
    Dec 3, 2003
    55
    port allen louisiana
    go to www.oldsgmail.com and look under chapter 5 in the search colum on the left. there is a write up you need. if i knew more about computers i would have done it for you.sorry
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    IIRC the single wire setups have a self exciter installed in the altenator.
