alternator question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83bowtyblazer, Mar 20, 2002.
  1. 83bowtyblazer
    83bowtyblazer 1/2 ton status
    Jul 29, 2001
    132
    Ft. Dix, NJ
    Has anyone ever installed a dual alternator setup on a K-5?? Just wondering. If so, how much of a pain in the arse is it to install??
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    It's more of a pain than you want to tackle. It's easier (and cheaper) to get a high output alternator and run a dual battery setup. But out of curiosity...what's it for?
  3. 83bowtyblazer
    Jul 29, 2001
    132
    Ft. Dix, NJ
    Nothing in particular. I was just wondering if it was possible. Thanks for the info.
  4. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Go for it! /forums/images/icons/smile.gif It's also a PITA to install a lift! It's also a PITA to install bigger tires!! It's also a PITA to do an engine swap to a Big Block!!! /forums/images/icons/shocked.gif
    The point!?! How much of a PITA is relevant. I just can't understand people on this board discouraging others from trying different mods! Why is it so bad if someone can show you how to hook up 200amps using cheap parts that you may even have lying around??
    Oh well; to each his own but I say go for it! I'm going to be running a dual alt set-up when my Blazer gets finished! /forums/images/icons/smile.gif
    Good Luck
