Alternator question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Apr 8, 2003.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Last Sunday I was using my winch and almost drained the battery. On the way back from the wheeling spot I noticed that the amp gauge was reading 15~16 amps on the freeway and 13 when in idle, before this it would read only 13 amps pretty much all the time. First I thought it was because the battery had been drained and it was recharging but all day yesterday and also today it was the same, I don't think it should continue recharging after 3 days. Any Suggestions? /forums/images/graemlins/confused.gif
  2. bajaviking
    Apr 10, 2002
    752
    Baja
    There must be somebody that knows /forums/images/graemlins/confused.gif
  3. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Umm, do you mean the voltage gauge reading 13 to 16 volts?
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If it's reading 15-16 volts you may have screwed up the altenator.
  5. bajaviking
    Apr 10, 2002
    752
    Baja
    Yeah, the voltage meter reads 15, before it used to read only 13.
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    CHECK YOUR FUSE!, i had a similer problem, and i ripped out the alternator, rebuilt it on my kitchen table, same thing, took it back out, check it again, put it back in same thing, went to autozone got a rebuild alternator, SAME THING, wait, did i check the fuse, fuse was blown, i call autozone right away, got my old alternator back, and money, BTW rebuild kits are cheaper then alternators /forums/images/graemlins/thumb.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  7. dyeager535
    26,979
    Don't trust the gauges with your life.
    Put a voltmeter on the battery while its idling. If the alternator is truly putting out more than about 14.5V, you've got a problem.
  8. bajaviking
    Apr 10, 2002
    752
    Baja
    Just checked it with the voltmeter, it reads 14.7 at idle and 16.5 when revving the engine. Smells like repair time. Thanks for the comments guys.
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Rebuilds your Alternator yourself, it really easy to do. Or if you're going to take it to a shop, have them build it into a high amp unit. It's always nice too have a 100+ amp unit if you've got a winch, off road lights, ... ect.
  10. dyeager535
    26,979
    I agree. If your stock one was working ok for you, rebuild it. Whopping $15-20 kit at chain auto stores.
  11. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    And, those rebuild kits work great too, nuthin like being a do-it-yourselfer /forums/images/graemlins/thumb.gif
