alternator specs.... from idle and up
Discussion in 'The Garage' started by RootBreaker, Nov 21, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Ok so my truck has a stock 63A alt. I know that 63 amps is at a certain rpm... anyone have breakdown charts that show the alternator amps per rpm's?
    I wanna compair this alt with a 140 pontiac transport.... I have the pontiac one but tried the swap a while back and it never worked for me... tried even with the $20 delco converter part.... autozone tested my alt and said it was good.. but i think maybe it isnt.... Im curious if the amps in the 140 at idle is more than what my stocker is.....
  2. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    The best thing about the cs144 is the high output at idle. IIRC it should put out somewhere around 80 - 100 amps depending on idle speed. That's just off the top of my head, sorry no charts or graphs.
    James
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I think the difference is about 4:1
    the 63 is around 15-25
    the 140 is around 60-100
    Its worth the 4:1
    Ps. most auto parts stores only test the output voltage, at no load
    they don't load it down with any amps, so many test good with no load.
  4. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
