Alternator upgrade
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Roostr84, Sep 20, 2001.
  1. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    I have to replace my alternator and was wondering if anybody upgraded to a better one like an CS model?
    Chris =)
    I think the exhaust fumes have finally gotten to me!!
    <P ID="edit"><FONT class="small">Edited by Roostr84 on 09/20/01 09:12 PM.</FONT></P>
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I looked in the yellow pages under Autoelectric and found a local shop that could assemble a 120amp alt that is a stock body or mounting. I think I paid 100 bucks like 5yrs ago and it's still running. TMake sure to ask for all the heavy duty bearings and coolong fan/pully.
    Good Luck
    PS never buy a chrome one, chrome reatins heat and heat kills altinators!
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I am interested in this too. I would like to upgrade to a newer style that puts out more amps. I woulden't mind changing the mounting I just want something that I will be able to get anywhere.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  4. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    I would go with a one wire alt. That way you do away with the regulator. I bought a 120 AMP Alt the day before i went to Hot August Night's. It cost me $60.00 and gave him my old one. This was the best thing i did to my Blazer with my TBI,and my elect,Dash,and Fan. 1 FN HI K5
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I did the 1 wire swap 1 month ago.EEE-Z. I removed all wiring i'm now not useing but it could as easily be taped up fastened out of the way.All gauges work like they are supposed to and the 140 amp puts out enough juice to power a D/C welder!I I got it from Summit racing for I think $90.00.I'd say go for a 1 wire conversion.
    <font color=green>BobK<font color=green>
  6. bitchin4x4
    bitchin4x4 1/2 ton status
    Jun 26, 2001
    106
    Denver, CO
    I too have a 1 wire. Awesome!! I actually did mine because I had a short somewhere that was causing my altenators and voltage regulators to fry out. Been running with this one over a year, not one problem (knock on wood!). Replaces the stock altenator, no modifications, etc. purchased through shop, local vendor.
    If it ain't broke, break it!
