Alternator upgrades....few questions
Discussion in 'The Garage' started by Bushwhacker, Nov 28, 2003.
  1. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    Did a search but nothing came up. I am looking to upgrade from the weenie stock one to something in the 140 amp class. I run a winch, fuel injection, rock lights, stereo, CB with some "heat", and fixing to install the Ford Taurus 2 spd elec fan setup. I was looking at Powermaster or Iceburg. What do some of you run for alternators?
    Thanks /forums/images/graemlins/thumb.gif
    Clay
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    My first job was at a Alternator and starter rebuilding shop. I highly recomend finding a local Alternator shop and have them build your Alternator up. It'll save you money, and if it has any problem, it's close to take back for repair. We normally did a 1 year warrenty.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    These guys have an impressive array of solutions: http://www.alternatorparts.com /forums/images/graemlins/cool.gif
    They also have the best price on Iceberg upgrade kits that I've seen anywhere. /forums/images/graemlins/thumb.gif
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    I run stock one myself. But what i was thinking of doing i know some of the people here have done is use 2 stock style alternators. Even though one might generally carry the load, if it is overcome the 2nd one kicks in and helps out. Also would be useful in the event of a crapped out alternator. Just a thought. Good question. /forums/images/graemlins/thinking.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  6. Bushwhacker
    May 13, 2002
    796
    Thanks for the input guys. /forums/images/graemlins/thumb.gif
    Clay
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes local electric motor shop will fix you right up if you tell them what you want and hand them an alternator
  8. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    there was a link posted on here before about using a 140 amp alternator from a '94 pontiac transport with an adaptor plug. i don't remember the link, but the alternator is about $100 from autozone, and the adaptor was about $20 from the dealer.
    Rick
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Rick
    See my link above. $96.99 for a lifetime warranty alternator from autozone.
    Application is 1994 Pontiac Transport 3.8L WITH REAR A/C
  10. tomy
    tomy Registered Member
    Jul 19, 2003
    34
    Orland Park, IL
    WOULD THE PONTIAC ALTERNATOR WORK IN AN 1989 K5? CAN I STILL USE THE SAME ALTERNATOR BRACKET? :confused:
  11. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    I just did this two weeks ago with the pont. transport alt. Best thing I ever did. I did have to modify the brackets . I had to relocate the top hole in the bracket and weld a tab to it so I could have some material to drill a hole in. Also for the bottom bracket I had to add a tab and re-drill a hole cause the alt. is big. It works great at idle as well.
    T.J.
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The biggest issue with "souping up" a stock 12SI alternator is that you typically only see a slight improvement in output at idle or slow speeds, which is where you really need it. The simplest swap is to upgrade to a CS144 large case alternator, you can either buy a new AC Delco unit or get a reman'd one at Autozone like suggested above (though if you go the AZ route they typically have core charge).
  13. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    Sorry, not trying to hyjack, but I picked up a couple of cs144's at Pick n Pull for $7.50 each...:cool1:
    Does anyone know if they make a rebuild kid for them? I looked online and couldn't fine one past the cs130.
    My first job was rebuilding starters and alternators also!!!
    Scott
  14. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    you want to rebuild one of those for me?:D
  15. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    Surpip, I sent you a pm.
