Alternator wiring? '91 K5 w/serpentine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Sep 2, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Alternator wiring? \'91 K5 w/serpentine
    Hey all. I've got a small case alternator, that has the 4-wire connector on the side of it, and the single charging pole off of the backside. My connector only uses two wires... but I have no idea where these two wires are supposed to go to!
    I "customized" the harness for my truck - and I don't have the schematics for the alternator wiring.
    Anyone out there have this info that you could post up for me?
    Thanks folks! /forums/images/graemlins/thinking.gif
    -Dan
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: Alternator wiring? \'91 K5 w/serpentine
    Okay, I'm thinking you might need the conversion plug, I guess.
    You are using the plug from the '86 and using an alt. from a '91?
  3. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I found the answer. The rear post goes to the battery (constant power, with a large wire direct to the battery), the F terminal on the side connector goes to the ignition swtich (switched power) and the L wire goes to the voltmeter.
    Just for the record, thats all. Thanks to Layne (K5BUILT4FUN) for that bit of info! /forums/images/graemlins/thumb.gif
    -Dan
