Alternator wiring question
Discussion in 'The Garage' started by cybrfire, Oct 19, 2003.
  1. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    OK, a friend of mine just gave me a 150 amp powerline alternator. (NICE HUH!!! Thanks Rob) Anyway, three wires, One is power out put and one is field exciter, Don't know what the third is. On your factory Chevy wiring I have a plug with two wires in it that I will have to remove and do not know which wire is field and the other. Any body know?
  2. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    TTT anybody?
  3. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Well, according to my wiring diagrams, the red wire on the back is for the battery. The brown wire in the connector goes to the light in the inst. cluster, and the white wire goes to the same splice point that the red wire goes to.
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    OK, you have the charge wire which comes out the back of the case and goes to the battery. Next is the wire which needs to carry battery voltage to tell the alternator how much to charch..it goes on the blade terminal on the left (if you are facing the pulley side). The remaining terminal is for your dummy light/ volmeter (it is not necessary for proper operation).
  5. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    I was doing some grave digging hear
    I am looking to get a electric feed for a electric fan I got the control set up but I need a feed the 3 wire ault should I feed it from the back post or the top red wire??
    /forums/images/graemlins/confused.gif
  6. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    I would feed all accessories off of a battery not directly off the alt. You can also get power distribution blocks for multiple Acc.connections that connect right to the battery. Check around at places that install stereos for them.
    Just my .02
