Alternator Woes
Discussion in 'The Garage' started by reecem, Nov 30, 2005.
  1. reecem
    reecem Registered Member
    Sep 23, 2005
    vancouver, canada
    I have a 1971 Blazer with a 1987 Short Block. All acc appear to be of 1971 vintage but serveral things were slapped together from the previous owner and I am trying to clean things up.
    Yesterday my charging system failed and I found something really wierd. The external regulator has pins 3 & 4 cut off! This to me means that the feedback of the regulator does not work but the truck has been running for 6 months so I am not sure what is going on.
    I dont really want to hook up the external reg, & get a new alternator if I dont have to, what I would like to do is hookup an internally regulated alternator and cut everything else out.
    Does anyone know how? Or have wire diagram.
  2. diesel4me
    Jul 24, 2003
    Could be..
    Someone might have already ditched the original alternator that used the old external regulator,and put in a later internally regulated one..a few trucks like yours I saw in boneyards had that done,and by using 2 of the 4 connections on the old regulator is a way to "cheat" and use the original wires,rather than run a new one from the key..
    I'd upgrade to the internally regulated 73-87 style altenator if one isn't already in it..its not hard to do,its a bolt in deal,and only 2 wires to mess with.. :crazy:
