alternator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mattyblazer, Oct 6, 2002.
  1. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    Hi,
    where does the red wire that is located in the plug on top of the alternator go. My truck was altered before I got it and I'm not sure that it is where it belongs?
    Thank you
    Matt /forums/images/graemlins/confused.gif
  2. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    to the bat or on the screw on the back!!
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    It goes to the same place as the other red wire on the alternator (that is not in the plug.)
    They both go to the junction block, which connects directly to the battery.
    This is fine for stock alternators.
    If you go to a higher output one or a 1-wire alternator, you should really just run a thick wire from it to the battery pos+.
    -- Mike
  4. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    BTW, you didn't really ask this but I'll mention it anyway.
    If you're not sure it's all hooked up right, test it.
    Put your multimeter on volts dc. Connect the red and black probes directly to the battery posts. It should read about 12.3 or so with the engine NOT running.
    Now, start it up. Do the same test, directly at the battery. Should read 14.6 or thereabouts.
    -- Mike
  5. mattyblazer
    Sep 22, 2002
    202
    Long Island, NY
    Thanks I'll try the meter
    -Matt
