Alternator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Strahan, Feb 7, 2004.
  1. Strahan
    Strahan 1/2 ton status
    Dec 4, 2001
    251
    Yoe, PA
    Driving home two nights ago coming down the highway and I say to my girl.. damn, these headlights are dim. I can barely tell they're on! I notice that the dash lights are dim too but they're turned up all the way. Check the volt meter it's in the red zone. So, I guess I can scratch an alternator. I figure if I have to replace it, I should replace it with something beefy.
    What's a good high amperage alternator to throw in my 83 Jimmy? Thanks!
  2. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    BTW I'm just assuming the alt. is bad. How do I test it? Is there something else that could cause that behaviour?
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    start the truck and hold a flatblade screw driver near the flat, round piece on the middle of the back of the alternator, if its pulled strongly to it, the alt is good, if it does nothing or if its VERY weak the alt is bad.
  4. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    Thanks. I called Auto Zone and they had a cheapy reman alt. for $50 so I figured I'd just throw that on for now so the truck's back on the road. Just installed it and fired her up. Hooked a volt meter to the battery and it read 11.21 volts, then every 3-5 seconds it'd drop a hundredth. After several seconds I was down to 11.17. Got in and set a block on the accelerator to rev it up and measured again, and it went back to 11.22 but still dropped, just took longer. The battery is only two weeks old and it now has a new alternator.. what else could be causing it?? Thanks.
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    you need to burn in the brushes in the alternator, go for a spin around the block with it, then re-check the voltage.. it should be around 13.2-13.6 at idle and near 14ish at 2200-2500..
  6. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    I took her out for a spin, went about a mile and a half. Came back and pinned the pedal again to let it rev higher and metered it again.. 10.05 and still dropping. I've heard you should change the voltage regulator when you change your alternator, but I didn't see one. Is it built into these alternators? If not, think that may be an issue?
  7. Confedneck
    Nov 1, 2002
    5,236
    have you tested the battery yet?? its a possibility the battery is fried, not accepting a charge..
  8. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    Nah, not yet. I just figured since it's only a few weeks old it was fine. Maybe the alternator croaking took out the battery too..? -shrug- Welp, I guess I'll run back to Wal-Mart and bitch about how it won't hold a charge & get them to replace it for free /forums/images/graemlins/smile.gif
  9. Confedneck
    Nov 1, 2002
    5,236
    sounds like a plan! /forums/images/graemlins/thumb.gif
  10. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    Well, I guess that was it! I called my local (Baltimore) Wal-mart and they said since I had no receipt I'd have to buy a new one. Called Wal-mart back where I used to live (Shrewsbury, PA aka Rednecks R Us) and they said "shuure thing buddy, bring yer dead bat-ry back in and we'll fix ya up!" hehe. Works good now. Voltage seems a little low, it idles around high 11s but as long as everything stays working that's fine by me, hehe.
    Back to the original question, does anyone know what the best or highest amp alternator is that I can throw on here? It's a 305 /w AC. I wanted to throw a nice one on now, but got impatient heh.
  11. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Batteries from Wal-Mart? /forums/images/graemlins/eek.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/shame.gif Don't you care about your truck? /forums/images/graemlins/rolleyes.gif
    Get the Optima Red top from Costco for $90 and be done with it.
    I have a PowerMaster 140 amp alt. Stock is somewhere around 60 to 80 amps. You can get a 200 amp alt from Wrangler or Premiere Welding (don't know their link) or you can get an 800 amp alt from Zena . Most people find that a 140 amp is sufficient. Expect to pay about $1 per amp until you start playing with the exotic alts.
  12. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Do a voltage drop test on your cables. If your cables/ends are no good, The juice WON'T get back to the battery.
  13. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    I guess I'll have to try that now /forums/images/graemlins/frown.gif I just got back from driving around and the !@#&*@#^%@ voltage is back down to the red zone again. I guess the false sense of victory was from putting in a fresh battery, it appeared to be fine cuz all the power was back.
  14. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    I just read somewhere that I should also check for a short. It said disconnect - and hook a test light between the batt - and the disconnected - lead and if it lights, I have a short. Well, I don't have a test light but I have a voltmeter. I metered the batt - to cable - and got 10.78v and rising so -sigh- I guess I have a short, eh?
    Anyone in/around Baltimore good with electrical issues? /forums/images/graemlins/grin.gif
  15. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    lets forget the possible short/draw, and concentrate on the charging system.
    ok, key on, engine off, you should have power at all the wires at the alt, all but one will be battery voltage, and the one(usually brown)will be lower than batt voltage
    check and post back
  16. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Buy a large case altenator from an electric shop. They are 100 amps stock and make almost full power at idle unlike most aftermarket alts. I got mine for 55 bucks. /forums/images/graemlins/thumb.gif Your current alt should be 78 amps with a/c, 63 without a/c.
    A 100 amp alt should be plenty as long as you are not running a huge stereo system.
  17. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    OK, I went out and metered it. On the plastic plug that plugs into the side the red wire was same as batt +, 11.48. The black wire was 2.69v. The red wire going to the bolt on the back of the alternator also read 11.40 something.
  18. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    Allrighty, think I have it tracked down. Came home for lunch and hooked up the meter to the batt - and disconnected - cable. 11.70 some volts. Went thru unplugging almost every fuse in there, no change. Then I thought to check the alternator. Unplugged the two cable plastic connector and the voltage dropped out. Checked the alternator pins and no continuity then checked and found continuity from the red wire to the + AND the - term of the batt and - cable. Ugh. So I guess the problem is in the cables from the starter?
  19. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    OK, I went back to Autozone and they tested the alternator and said it was bad. The one they just sold me heh. So they didn't have any more of the Valucraft reman'd in stock so they gave me a new Duralast even trade /forums/images/graemlins/smile.gif Got in, fired it up and the meter in the truck was up over 13. Whew! Hopefully it's fixed for real this time, heh. Thanks for the help guys.
  20. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Living where I live, parts stores are always at least 25-30 miles away. I got two bad parts before, and since then I have the store test the NEW stuff before it goes out the door. They do kind of look at me funny though. /forums/images/graemlins/smile.gif
    John
