Alternators
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txguy, Sep 8, 2001.
  1. txguy
    txguy 1/2 ton status
    Sep 4, 2001
    114
    Round Rock (Austin) Tx
    Has anyone ever heard of running 2 of them? Possible?
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I have heard of running 2 alts but usually you need to find another bracket or fab up your own for the left side of the motor and really why bother. I would go w/ a dual battery set up and run one of the Huge alt's from Wrangler. Just my $.02 plus then you can keep your ac [​IMG]
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  3. txguy
    Sep 4, 2001
    114
    Wrangler? I have heard of Powermaster...
  4. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    I'm not a very big Powermaster fan right now. I got a 140 amp from them and it has been a PIA. They sent me a V belt style one and when I called they said switch the pulleys to the semi-serp style you have now. Well it doesn't take a rocket scientist to see the V belt pulley is a lot smaller then my serp pulley so thus the alt turns slower. Only place this makes a problem is at idle it only keeps the sytem going a about 12,4 volts... when you take the idle rpm up a few hunreded rpms to 800 or so it is ok and puts out enough voltage. So now I'm stuck trying to find a pulley set for the V-belt style or hoping Wrangler makes an overdriven pulley in my style belt. Other then that no problems... just kinda annoyed w/ them at the moment LOL [​IMG]
    Here's a link to Wranger's sit...
  5. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I got the Wrangler 140A with a new pulley, and charging wire kit..(0/1 ga...looks like jumper cable).....fixin' to add another battery when I feel energetic enough.....you can get Alts up to about 200A.....I've got about $200 in my setup.....JD
    Stuck?...Hell no..I still got some gas left..
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Absolutely no reason or need to. I too have the 140 amp WranglerNW model with the direct charge (massive) cable for over 3 years now and it flat kicks butt.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
