alternators
Discussion in 'The Garage' started by rick88blaze, Sep 22, 2003.
  1. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    has anybody here heard of putting an alternator from a '90's cadillac in a truck? i talked to an alternator shop today about upgrading my alternator, and he said my best bet would be to get one from a '90's caddy. any input would be great. /forums/images/graemlins/1zhelp.gif
    rick
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Yep, my altenator shop told me the same thing. Certain year Cadillacs and Olds (IIRC), he had all the specifics if I wanted to search the 'yards. /forums/images/graemlins/thumb.gif
  3. dyeager535
    26,982
    191
    I think this swap (or similar) has been discussed on this board previously, but here is something that may give you some ideas.
    high power alternator
  4. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    the escalades have something like a 140 amp alt in them stock.
  5. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    thanks for the link. now i know what i'm going to do for the swap. order the adapter from GM, and go buy a lifetime alternator for a caddy, from a parts store.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's not looking like that adapter will work for our trucks. Look again.
  7. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    chevy dealers carry those. when i get ready to upgrade my alternator i'm going to order the adapter first and see if it will work or not. i'm not going to do this for over a year from now, but i'll keep this thread handy so when i do, i can post up if it works or not.
    rick
  8. dyeager535
    26,982
    191
    I can't tell on that gray end, which appears to be what the stock white plug would fit into. Not sure when GM went away from that white two terminal connector.
    That gray connector does have a weird "angle" on the two shoulders of it, but if nothing else, looks like it may be as easy as a cut and splice of the old alternator wires to that harness.
  9. BXwildshot
    BXwildshot Registered Member
    Sep 17, 2001
    97
    Bronx , NY
    Any year caddy in particular? Any particular model?
  10. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    when i checked the computer at Autozone, the 140 amp. alternators started in '92 if i remember right. just look up a mid '90's. they are all 140 amp then. the link in dyeager's post lists a '94 pontiac transport. i looked it up too, it's also a 140 amp. /forums/images/graemlins/thumb.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Now that I look at it again, that adapter may actually work for our application. You're right...it's funny shaped, but it does have two prongs like ours.
  12. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have a 160 amp from a GMC c60-c70 series truck. It's the same depth as the standard alternater, but the case is 1/2 inch taller. The wire harness uses the SAME connectors. The only things I did to fit it was elongate the bolt hole for the upper bracket that mounts to the water pump and use a stud topped intake bolt and a small spacer for the part that bolts to intake manifold. The stock lower bracket and pivot bolt fit fine. The best part was it was only 100.00 reman and is compatable with the onboard welders. The newer type alternaters that are considered "CS" types are not compatable. and generally cost alot more.
  13. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    where did you pick up that 160 amp alternator at? i'll have to check into that. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  14. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I got it from a local alternater/starter rebuild shop. I also got my High torque Mini starter from him. I'll see if I have the cross over part # for it. But check with your local rebuilder. I wouldn't go to a generic parts store, most of them are clueless! This alternater spec'd out at 163 amps at 5,500 alternater rpm. which is about 2,000 engine RPM.
  15. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I'm not worried about parts people not being able to cross ref. part #'s. i can do that myself. i used to work part time at autozone. that and i've already looked up the caddy and pontiac part #'s. there is a local shop here that can build me a high amp alternator, but they only have a 1 year warranty, and i'm leaving here next year. if i get the caddy alternator from autozone, i get the lifetime warranty good at all the stores.
  16. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I went to the junkyard and rummaged through a buttload of cars before they went to the crusher and found these 140amp alternators in tons of different kind of cars from Cutlass Cieras to Bonnevilles. I picked up two decent looking ones and one has 1 wire running to the alternator and the other has 2 wires running to the alternator. Other than that, the alternators look nearly identical. What's going on?
    I'm going to have my Dad pick me up a couple of those converters and ship them to me since I can get two of them for the price I can here and then I'll try them out. I tend to smoke alternators regularly because I like to play in the water and being able to run my electric fans and blower without losing a couple volts would be nice.
  17. dyeager535
    26,982
    191
    How much do you pay for them, and what do rebuild costs run, if you know?
    Just curious what kind of investment it will take to run one of these things. Have no problem running a "used" alternator, as long as I'm the one that rebuilds it. If the rebuild cost is as cheap as the older ones ($20) then I'm all ears.
